10-04-2014, 09:14 AM
1992 29' Excella
Virginia Beach
, Virginia
Looking to replace my Electric Tongue Lift
Hi,
I have a 29' 1992 Excella Classic. My I'd like to replace my electric lift and was wondering if there are some better models I should definitely be considering.
The lift on my AS is older and making some terrible noises. Also the allen screws are frozen and allow the motor to twist the entire housing back and forth. So, I think it would be best to replace it with a whole new lift.
Pete
Virginia Beach, VA
1992 29' Excella Classic
TV 2006 Dodge Ram 2500
Mega Cab Diesel 4x4
10-04-2014, 09:37 AM
Princeton
, New Jersey
Super Jack 3500 by H&H Engineering. It ha been the standard for years. It has capacity and speed. Some of the newer jack are so slow the weekend is over before you are disconnected.
Oh yes. They stand behind their product.
2004 Excursion 4x4
10-04-2014, 10:31 AM
1987 25' Sovereign
Oregon
, Ohio
I replaced mine this spring with a Husky Brut. It has a 4500# rating. The unique thing about is that it has ball bearing setup in the threads of the screw lift not just friction threads. It has worked good this far, so now I what the test of time.
10-04-2014, 04:02 PM
1987 32' Excella
Nepean
, Ontario
I replaced mine about a year ago with the Husky as well. One thing I was unaware of was that with the Husky, you can remove the holder for the umbilical cord (the power cord from the TV to the trailer) and then it will fit flat against the propane tank cover.
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
WBCCI 8080
10-04-2014, 04:13 PM
1992 29' Excella
Virginia Beach
, Virginia
Is this the one you're talking about? http://www.barkermfg.com/vip%20jack%20new%20%282%29.jpg
Pete
Virginia Beach, VA
Mega Cab Diesel 4x4
10-04-2014, 04:15 PM
1992 29' Excella
Virginia Beach
, Virginia
That Umbilical holder is pretty nice. To bad it doesn't fit.
Pete
Virginia Beach, VA
Mega Cab Diesel 4x4
10-04-2014, 04:17 PM
2007 30' Classic S/O
Somewhere
, South Carolina
Got Husky too. Impressed by the ball screw system too. I have a friends Barker Super Jack 3500 on the bench trying to make it a spare for its owner. It seems to have failed from p poor soldering on the switch terminals. Also it has about 6 spots where the wire insulation at the switch area is crushed from pinch fit of cover over wires including the motor feed wires being crossed under the cover, really compressed. Not looking real good right now.
Also Husky does not require removing the power head for manual operation.
10-04-2014, 04:19 PM
Somewhere
, South Carolina
Re Pete,
I put the plug holder on the side using outdoor double sided tape. Working for me.
Gary
10-04-2014, 04:41 PM
1992 29' Excella
Virginia Beach
, Virginia
I have the Reese Dual Cam Hitch set up which requires lifting the tongue after it's connected to the trailer ball. So, I'm lifting the back end of 2500 Dodge Ram truck as well to finish hooking up the cams. My main concern is having enough lift power. I never considered speed, I guess because my current lift seems fairly quick.
What is the expected life of a power lift? We go on some pretty long trips every year, moving on average once a week, so, my lift gets a lot of use. Right now the one I have, no idea what brand it is, sounds like it's grinding gravel when I use it and like I've said it's loose where it's mounted at the top of the "pole".
Both the Husky and the Super Jack seem adequate. Anything else to add?
Pete
Virginia Beach, VA
Mega Cab Diesel 4x4
10-04-2014, 05:11 PM
2004 28' Classic
Fresno
I put a Barker on my last two Airstreams. Very happy
Doug & Lori
Fresno
2004 28' Classic
2007 Ram 2500
10-05-2014, 02:12 PM
1987 32' Excella
Nepean
, Ontario
Actually, I had the dealer who sold it to me drill out three holes for the bolts with the jack turned sideways. I had to remove the light on the side that is against the tank cover. So I have minimal light, but the umbilical cord plug is nicely protected.
I'm also using the Reese Dual Cam and the Husky works well with it.
VE3JDZ
AIR 12148
WBCCI 8080
10-05-2014, 02:53 PM
1992 29' Excella
Virginia Beach
, Virginia
Does anyone know what the expected life of an electric trailer lift is? Just curious.
Pete
Virginia Beach, VA
Mega Cab Diesel 4x4
10-06-2014, 09:43 AM
1987 32' Excella
Nepean
, Ontario
That's a crap shoot!
The original one on my AS (1987) died 2 years ago - so 25 years. The first Husky died within a year and was replaced under warranty - and the replacement is working fine.
VE3JDZ
AIR 12148
WBCCI 8080
10-06-2014, 07:37 PM
1992 29' Excella
Virginia Beach
, Virginia
Thanks to everyone for they're help and advice. I decided to go with the Husky. Mostly because it was recommended almost equally with the Barker and because it was available through Amazon Prime, so I'll have it in a couple of days.
Pete
Virginia Beach, VA
Mega Cab Diesel 4x4
10-11-2014, 10:20 PM
1992 29' Excella
Virginia Beach
, Virginia
Husky Brute 4500 Installed
Pete
Virginia Beach, VA
Mega Cab Diesel 4x4
10-11-2014, 11:11 PM
1974 Argosy 20
Kooskia
, Idaho
I have no idea about the new ones, but I had two Reese electric jacks that I moved from trailer to trailer for years. Both were made in the early 1980's, and were/are small, quiet, powerful and very fast. I sure wish Reese made the identical unit today. The powerhead is smaller than any unit now available now.
I sold one with my '71 Caravel, the other is still in good operating condition and is used on my '74 Argosy. Neither unit ever needed any repairs, but the plastic motor case eventually cracked on both. I repaired it with Aluminum tape and painted it again. Still working fine.
01-01-2015, 03:05 PM
1996 34' Limited
1976 31' Sovereign
1983 31' Excella
Greeneville
, Tennessee
I replaced mine with a Husky from Camping World, 4500 lb, with a extendable foot, and it also came with a remote (not what I bought it for, was on sale and extendable foot).. it has performed flawlessly and I am extremely pleased with it. The remote I did find that it was extremely handy in hooking up as I no longer have to jump in and out of the truck when hooking up if I don't get the tongue up high enough or once I am under it I can let it down onto the hitch while holding the break on the truck to keep it from rolling that little bit that puts you just not far enough or too far under, and I know everyone has experienced that problem.
Sarge USAF
WBCCI- none
Good Sam Life Mem
NRA, DAV, PGR, DRA
01-04-2015, 11:38 AM
Winemaker
2022 25' Flying Cloud
Avila Beach
I have a 2012 28ft.FC. As my trailer is not stored close, can someone tell me what stock lift was installed on it?
01-04-2015, 12:53 PM
Princeton
, New Jersey
If the Baker Super Jack is still available but it directly from them. Most of the newer jacks are Chinese junk.
http://www.barkermfg.com/superjack.jpg
2004 Excursion 4x4
01-04-2015, 01:59 PM
Vintage Kin
Fort Worth
Sadly, appears to be discontinued as a new product, but parts are available through Barker.
