Old 01-05-2020, 09:21 AM   #1
2020 27' Flying Cloud
Looking for options for fixing front compartment gap issue
Hello, I am looking for suggestions on how to correct an issue on the front compartment on my Flying Cloud 27FB. Two pieces of aluminum come together and have a rubber cover that hides the gap, but the gap is too large and the cover keeps coming off. I was not in any real rush to fix it but I cut my finger open loading the compartment on our last trip.
Is this possibly a warranty repair issue?
Picture is attached.
Thanks for your help.
Brainodo is offline   Reply With Quote
Old 01-05-2020, 10:00 AM   #2
2018 25' International
Slidell , Louisiana
Spring steel sheet metal clips will work or better aluminum rivets. If you go with the clips, paint them first so they don't corrode the aluminum. Once the pieces are closer together it should be fine. if the gap is easy to close, some double sticky 3M tape in between and a pair of pliers will also work. I have used all three methods.
Brian
Old 01-15-2020, 02:40 AM   #3
2019 27' Globetrotter
Dallas , Texas
Just use pliers, just remember to use something in both sides of where you'll use the pliers so that it wont scratch it.
One of the most difficult tasks in gardening is getting rid of the pesky leaves everywhere.Check this Echo PB-580T Review https://gardeningfacts.org/best-back...b-580t-review/ to know more about its features.
Epimyth is offline   Reply With Quote
Old 01-15-2020, 07:42 AM   #4
Overkill Specialist
GMFL's Avatar
2014 23' International
Dadeville , Alabama
Pop rivet the two sheets together. Warranty? Yes, but I wouldn’t bother. Just clamp it together, drill, and place a few pop-rivets in place.
GMFL is online now   Reply With Quote
Old 01-22-2020, 11:44 AM   #5
My first rivets
Thanks for the replies. I was going to use the 3M double sided tape but I figured that I should learn out how to do the rivet thing. It worked out well!
Sorry for the upside down and sideways pics, maybe I need to learn how to do that correctly next.
ID:	359674   Click image for larger version
AC replacement-options, options... Belegedhel Furnaces, Heaters, Fireplaces & Air Conditioning 5 09-12-2018 09:56 AM
'Fixing' front window Zeppelinium Windows & Screens 25 04-16-2013 06:22 PM
tub/shower wall gap RevBec Sinks, Showers & Toilets 5 08-19-2007 07:59 PM
1975 Argosy MH 454 proper spark plug gap? cejohnsonjr Mechanics Corner - Engines, Transmission & More... 2 04-21-2006 11:17 PM
Gap between floor and shell tmcdougald Repairing/Replacing Floor &/or Frame 4 07-19-2005 06:44 PM
