Old 11-05-2013, 08:26 PM   #57
Jim Lee's Avatar
1978 31' Sovereign
1984 31' Excella
Springfield , Missouri
Images: 125
here's a gutted Airstream on ebay now. (Not mine)
It's in Michigan I believe.
Vintage 1974 Airstream Excella 500 Land Yacht 31ft Ready for Restoration | eBay
Jim Lee is offline   Reply With Quote
Old 11-06-2013, 12:34 PM   #58
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Originally Posted by pckeen View Post
<snip>I build fine furniture, so I have some skills to start out with.
My difficulty right now is I don't know the extent to which I'm ignorant about restoring airstreams - I do know that I want something that is structurally sound.
One thing I would caution you about, is many furniture / cabinet makers have a hard time scaling things down for an Airstream. The vintage Airstream frames are relatively lightweight and you have to really be careful not to overbuild and make the new guts weigh a bunch more than what you take out - the standard frame can't handle it. As long as you keep the construction type & materials similar to the original, you should be fine - if you are going in with full box cabinets, you'll be adding alot of weight.
We rebuilt our 1956 Safari from the frame/shell in - and still kept it under 3,000 lbs.
My assumption was $8-$15k, assuming I do all the fabrication myself.
I would say that's a pretty conservative estimate...it could be double depending on your taste in finishes and whether or not you have all the tools you need to get the job done. Ours was well over $15K and we had a smaller trailer and did all the work ourselves too.
Good luck in your search!
Shari
Old 11-07-2013, 06:48 PM   #59
Dryden , Ontario
It sold for a little over $2k - this seems to be the going sort of rate for a gutted, but not rebuilt 60s/70s 31 footer.
I was concerned about that - my furniture is typically substantially heavier than store bought stuff....My plan will be to build frame and panel cabinets, with the panels being 1/4" ply or 1/4" solid boards.
Sounds like you have a fantastic trailer - the good news is I hope to spread the expenses over a few years.
Thanks for all the comments
pckeen is offline   Reply With Quote
Old 11-07-2013, 07:00 PM   #60
DavidsonOverlander's Avatar
1964 26' Overlander
Milton , ON
You might also consider the method that Smokeless Joe used in his Argosy project. It's described in post 93 in his Contemporizing 1976 Argosy D - opinions please thread.
Grant Davidson
Milton, ON
1946 Spartan Manor
1954 Va-Ka-Shun-Ette
1964 Overlander
1965 Avion C-10 Truck Camper
1974 Sovereign
2005 F-350 SRW 4x4 crew cab long box
TAC ON-5
DavidsonOverlander is offline   Reply With Quote
