Old 10-11-2014, 10:42 PM   #1
Re-Pete's Avatar
1992 29' Excella
Virginia Beach , Virginia
Looking For A Fix For A Broken Propane Tank Lid / Latch Catch
Here are two pictures of the back side of the propane tank cover showing the latch and the missing portion of the lid where the catch used to be. This lid is plastic (not sure if they all are). Does anyone have a fix for this? Both pictures will enlarge if clicked. I'm currently using a bungee set up to hold the lid closed while traveling. We're off to the Blue Ridge Parkway day after tomorrow for a week of autumn leaf watching, which I mention in case I seem slow to respond.
ID:	224158 Click image for larger version
Pete
Virginia Beach, VA
1992 29' Excella Classic
TV 2006 Dodge Ram 2500 Mega Cab Diesel 4x4
Re-Pete is offline   Reply With Quote
Old 10-11-2014, 10:48 PM   #2
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
I would just rivet a piece of 1/8" thick aluminum stock that is the same width as the lip and buy a new over center latch to fix it close to stock.
This will work well, it will look good, and it will be cheap and easy. The aluminum stock is available at Home Depot as is the over center latch.
I would run the stock the full length of the cover.
On edit, i might use screws and nuts instead of rivets due to the possibility that the ends of the rivets might get in the way of the lid closing right.
If you use machine screws and nuts, you can trim/grind the screws flush with the nuts to minimize interference.
Old 10-12-2014, 03:12 AM   #3
sandlapper's Avatar
1993 34' Excella
York , South Carolina
If you don't mind spending a few bucks, just replace the top and the latch. Out of Doors Mart has them both. John
John
WBCCI #3892 Palmetto State Airstream Club 22
Region 3 , 1st VP
Go often to the house of a friend, for weeds choke the unused path........Emerson
Are you kind?
sandlapper is offline   Reply With Quote
Old 10-12-2014, 09:23 AM   #4
Re-Pete's Avatar
1992 29' Excella
Both good ideas, I wasn't sure if the just the lid was available. Also I purchased a sheet of aluminum about 4" x 12" x 1/16" two days ago with the idea of cutting out a piece to fit across the lip of the lid. Fasteners, of any sort, to hold it on seem problematic. I'm going to look into replacing the lid and see what that costs. Thanks for both suggestions.
Pete
Virginia Beach, VA
Propane tank cover lid replacement. desertair27 LP Gas, Piping, Tanks & Regulators 21 12-07-2012 09:12 PM
Spring broken in outside main door hold back latch catch Biggysmalls Doors & Locks 6 05-14-2010 11:56 AM
Sliding Latch Door catch broken '72 Tradewind RichHog Doors & Locks 8 09-25-2009 04:04 AM
Propane tank cover lid airstreamed Clearcoat, Exterior Paint & Trim 1 11-24-2008 04:18 AM
Excella Double Propane Tank Shroud Lid rmscottrds LP Gas, Piping, Tanks & Regulators 3 04-08-2007 06:03 AM
