Old 01-21-2010, 03:48 AM   #15
scf31's Avatar
1977 25' Caravanner
Jeffersonville , Kentucky
LOOK , LOOK, LOOK ,,,, look all over,,,, I looked for 8 months and did a lot of traveling over several states, finally found "mine" in the next county . take your time ,
Movie Stars and Film Crews come to Me from hundreds of miles enticed by My knowledge, My imagination,expertise, creativity and innovations!
scf31 is offline   Reply With Quote
Old 01-23-2010, 02:30 PM   #16
Mechanicsville , Virginia
Well went and visited the airstream today. Here is what i found
1) Rear separation, had a friend stand/jump on bumper body and bumper traveled pretty close, maybe about 1/4 in lag....
2)trailer hasnt been licensed for road travle since 95. Its been sitting still for a long time
3)no visible leaks or water stains. Looked at every window.
4) Cut several holes in carpet, sub floor seemed strong no visible water damage
5) Saw day light in a couple of places around rear bathroom, basically pin holes in plastic seams.
6) NEEDS new tires and should have bearings packed (noted before).
7) Sofa needs to be pulled.
8) Checked underside no visible rust.
9) NO rivets were elongated
10) needs a new AC cover, furnace and probably a water heater.
11) Electrical worked, plugged in and all lights worked.
I have attached pictures, not sure how helpful. What should I be seeing.
ID:	94615   Click image for larger version
ID:	94617   Click image for larger version
ID:	94622   Click image for larger version
ID:	94624   Click image for larger version
F250PUP is offline   Reply With Quote
Old 01-23-2010, 02:57 PM   #17
Could have been worse.
Old 01-23-2010, 03:19 PM   #18
Thanks Andy, i was hoping you would look. I offered the guy 1500 for it. i think at that price I get a great deal. If I replace the tires and bearings, which I think is the major issue. I can do the rest pretty easy. What do you think?
Old 01-23-2010, 06:19 PM   #19
RichHog's Avatar
1972 25' Tradewind
Houston , Texas
Purchase Price is where it starts
Consider that you are going to invest a lot of your own cash on this trailer to do the modifications to make it your dream trailer. $1500 is a very good price if it has the potential once you start working it over. Make sure the outer skin is in good shape, that's the hard one to repair and replace the dents. You can easily spend another $5,000 on upgrades, flooring, fridge, oven, furnace etc.
But when all's said and done you'll have a trailer worth much more than you paid and will last a long time. Go look at a new $50,000 Airstream and you'll feel even better.
RichHog is offline   Reply With Quote
Old 01-23-2010, 07:18 PM   #20
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
However much you think it will cost you to fix the problems you find initially, double that amount. First, all the little things you wind up buying to fix the big things really add up even if you have a lot of tools and are handy. Second, you will find all kinds of things that you will want to make better even if they are working when you buy it. Consider the cost when you come to terms with a price with the seller.
Old 01-23-2010, 07:18 PM   #21
Before you attempt any repairs, you should find out everything the trailer needs, to get it back up to snuff.
In that way, you can better prepare your time, and budget, as necessary.
If it's going to cost several thousands to fix things up, then as long as you are aware of that, before you spend any money, then the end result will not be disappointing.
The first major repair, is to make sure the coach is "water tight". Check all the exterior gaskets, including the sewer vent pipe cover gaskets, which only last 2 to 3 tears. If they are original, then they all should be replaced, to keep the rain out.
Once the trailer is water tight, that doesn't take much time or money, then as your time and budget allows, you can attack the list that you prepared.
You asked about the axle. Read the article in the Airstream Central part of this Forums. It will teach you how to easily check out the axle condition, without taking anything apart.
You will need a small bottle jack to do one of the tests, however.
Generally speaking, leave the cosmetics until last,. Strive to correct all the safety issues first, especially the LPG system for proper pressure and no leaks. Check both the 12 volt DC and the 120 volt AC systems.
Check the AC, the furnace the water heater, etc. Replacing the reefer is easy but determine the dimensions first so that you have a proper fit.
And the bottom line is, welcome to Airstreaming, and hopefully with some help, some of us can contribute to your future "happy Airstreaming".
Andy 8.9
Old 01-24-2010, 01:29 AM   #22
1970 25' Tradewind
Hampton , New Hampshire
I am also looking for an Airstream and sweating the inspection process. I recently looked over a 1970 Trade Wind, asking $3500.
The thing had a million little problems like: broken step, frige gas hookup cut and left open, water line left unsoddered, vent damaged and capped with a trash lid, keys missing, bumper hatch that gains access to umbilicles missing hinges, gaucho cushion missing, cubby covers missing, attenna installed on curb-side by front window, big piece of rubber pasted to bathroom floor (not a good sign), daughter of seller put some kind of flame art outlines on the exterior, window missing clip, side windows replaced with some kind of plastic, tougue jack bent, tires lightly dry rotted, pie-sized dent in low front corner curb-side. Not to mention that no appliances or lights were tested.
Other than that the Airstream seem sealed from the elements. I didn't do the sag test or check the axles. Has $800 awning. The seller says the tow functions work so I don't feel nervous moving it to storage a few miles away.
I think I will offer $3000. What do you think? I'm excited and nervous. Hopefully it will be a "labor of love" or shall I find a better AS. Thanks for your input.
timdfrost is offline   Reply With Quote
Old 01-24-2010, 01:42 AM   #23
From your description, that trailer has been neglected and abused.
I would bet that all the exterior gaskets need replacing because they don't last 40 years. Thesewer vent pipe gaskets only last 2 to 3 years.
I would also check the axles out. If they are bad, that's a huge expense to start. More than likely the brakes are bad as well.
The sheet metal panel, with no labor, is at least $300.00 or more.
The windows are, ball park, $300.00 each or more.
To refinish the exterior, will cost at least $3000.00, if you have it one.
Granted, getting a salvageable coach to tinker with, can be alot of fun, but it can get to be real expensive, quickly.
I think a $1000.00 offer, would already be generous.
But, it's your call.
Old 01-25-2010, 08:12 AM   #24
RichHog's Avatar
1972 25' Tradewind
Houston , Texas
70 Tradewind
Fixerupper Airstreams can go in the $3,000 mark. A friend bought a 69 Overlander for $3400 and did a lot of work restoring. I think most anybody that has taken on that project winds up with an investment of $10,000-$15,000.
Andy is right about the essentials and axles, windows, gaskets and vents all add up. Decide if the work needed is something you want to do for man therapy. I've had a blast working on my 72 Tradewind and at first was nervous about it but as I've gone along I've taken on a lot of upgrades I once would pay for instead of doing myself. Bottom line is to negotiate the lowest purchase price on it and then go to work. Somebody will always pay more and it will get away from you. Also I have a Gaucho Cushion from my Tradewind if you need it.
Old 01-25-2010, 04:15 PM   #25
1970 25' Tradewind
The Rivet Master above got me a bit psyched out about the 1970 Trade Wind. (I pretty sure the guy won't go for $1000.) But I found this 1962 Trade Wind on craigslist: http://youngstown.craigslist.org/rvs/1551599087.html (please don't make this an ebay auction!)
I made him an offer of $5,600 over email. I will have to finance the purchase now, but I think this Airstream looks like a winner and moreover, livable in.
Old 01-26-2010, 08:15 AM   #26
RichHog's Avatar
1972 25' Tradewind
Houston , Texas
70 Tradewind vs 60s
Looks like a nice trailer on Craig's list. There are quite a few differences between the 60's and 70's Tradewinds (24' vs 25'). The nice thing is if the wood interiors and all of the overhead bins work then you've got a styling trailer.
I replaced and covered up the plastic laminate on mine with wood veneers giving me the look of the 60's interior.
1970 Airstream 31 ft Land Yacht eBay Watch Airstreams on eBay 0 07-05-2009 09:30 PM
1970 Airstream 31 ft Land Yacht eBay Watch Airstreams on eBay 0 06-15-2009 04:20 PM
1970 Airstream 31 ft Land Yacht eBay Watch Airstreams on eBay 0 04-28-2009 05:40 PM
1970 Airstream 31 ft Land Yacht eBay Watch Airstreams on eBay 0 04-06-2009 04:00 PM
Looking at a 1970 Land Yacht 30' Griswolds Trailer Values 8 03-21-2006 05:55 AM
