Old 01-02-2019, 08:13 PM   #43
2004 22' Safari
Albuquerque , New Mexico
Originally Posted by stoneager View Post
Sorry to hear this. We had something similar happen to us with out 2018 16RB. We were locked inside at Garner State Park. Like you, my tools were outside, however, I did have a leatherman tool inside the camper. The problem for us was that the screen door frame blocked a couple of the screws to the door latch mechanism. I was only able to take out one screw. After about 30 minutes with the leatherman and a flashlight I was able to figure out how to release the latch mechanism after prying only one side of the mechanism open by about a half inch.
Of course this was a minor problem compared to the leaky door on a brand new Airstream that took months to fix. We think. Maybe. But that's another story.
I heared of an Airstreamer who then drilled two holes in the screen door frame to be able to get to the necessary machine screws.
Silver.Sanctuary is offline   Reply With Quote
Old 01-03-2019, 07:34 AM   #44
Dennawayne
2015 30' International
On the Road , Washington
Permanent fix
I got tripped up on posting the pictures for the machine screw fix so they are in there but not with my post. They appear as a series of photos starting with a picture aDeWalt package with a drill and a tap for 22 threads per inch. Use that to tap the aluminum entry handle. The other photos are self explanatory. Good luck if you choose to do it. Sorry to here about the door.
Dennawayne is offline   Reply With Quote
Old 01-03-2019, 10:34 AM   #45
Ayr , Ontario
The same thing happened twice now. I just pulled the screen spline out a bit reached out of the window and opened the door. Not a big deal. A couple of minutes to take the door handle apart and reassemble it. And another couple to push the screen spline back into place. Overall it takes less than 15 minutes. I have a fix planned that will be permanent, but I need to make some parts for it so it's on the back burner for now.
I took a look at what others are doing and decided that's not the route I want to take.
Yes this is a design issue. Too bad AS doesn't offer a proper fix.
gator.bigfoot is offline   Reply With Quote
Old 01-03-2019, 10:37 AM   #46
RFP
RFP's Avatar
2014 23' International
Hurst , Texas
Originally Posted by gator.bigfoot View Post
< snip > I took a look at what others are doing and decided that's not the route I want to take.
< snip >
So, what are you going to do? C'mon share with the rest of us
2014 23D International Serenity - "Fortune Cookie"
2015 Ford F150 3.5 EcoBoost, Max Tow - "Cookie Monster"
And some stuff
Fortune Cookie: https://www.flickr.com/photos/rfpd30...57663633667345
"The Black Swan": https://www.flickr.com/photos/rfpd30...57648991024725
RFP is offline   Reply With Quote
Old 01-11-2019, 07:22 AM   #47
2018 30' Classic
Callao , Virginia
Originally Posted by Mollysdad View Post
I'm planning to add this and stop pulling on the handle.
Kudos to the forum member who posted this.
Thanks for posting this pic! I was thinking about doing this after our handle broke off and we had to improvise to get out.
Airhead2018 is offline   Reply With Quote
Old 01-12-2019, 10:26 AM   #48
2004 22' Safari
Originally Posted by Hicks3456 View Post
Same thing happened to us. Except I had to go out the emergency exit and go around to open the door. Airstream replaced the lock and screen. Airstream is aware of it but has not done anything to fix the problem.
When they were repairing the lock I was able to look at the mechanism and see how to manipulate the post to open with small screw driver. This would be a nice procedure for the owners manual.
Airstream needs to take a lesson from car manufacturers and come up with a system like on the back of many SUVs where the door shuts and the mechanism quietly and firmly pulls the door into a locked position.
Old 01-14-2019, 07:47 AM   #49
2018 30' Classic
Callao , Virginia
The problem is cheap pot metal parts. I took a suggestion from a previous post and installed a handle to close the door with. Hope it last!
Name:	My Door Handle.jpg
Old 01-14-2019, 07:56 AM   #50
RFP
RFP's Avatar
Hurst , Texas
I respectfully disagree. The "problem part," the door handle is not cheap pot metal, it is cast aluminum and as a handle is quite adequate for the job. The problem is the way the handle is attached to the metal actuator place on the backside of the assembly: it is seeded.
The gold standard "fix" for this problem is to drill and tap the handle for a 1/4-20 machine screw and fender washer as shown in earlier posts. That "fix" is a ten-minute project and is a final fix and makes to footmans loop completely unnecessary.
And some stuff
Old 01-15-2019, 08:01 AM   #51
2018 30' Classic
Callao , Virginia
RFP, When our handle broke it was the handle itself meaning the part you grab came of in my hands and the part you describe drilling and tapping a 1/4-20 screw into was still attached to the door. So what was left was a little round knob to try and turn to get the door open. Your "gold standard" would still be attached as our factory standard was. I have a picture somewhere I can dig up if this is not a good explanation. Hope it doesn't happen to you our anyone else.
Old 01-15-2019, 08:16 AM   #52
RFP
RFP's Avatar
Hurst , Texas
Wow... No, your explanation is perfectly clear and really surprises me. Clearly I stand corrected in my assessment of this issue. This makes me wonder if the material used in your 'handle' is (was) different from that used in mine. My handle is clearly a cast aluminum piece. I'm wondering if yours was, indeed, cheap pot metal... If so, this changes everything.
Thanks for the update/clarification
Rob
And some stuff
Old 01-15-2019, 08:37 AM   #53
GettinAway's Avatar
2011 23' FB Flying Cloud
Chesterfield , Missouri
Did AS change the handle at some point? I’ve never had issues with ours (2011)
We do have to close the door pretty firmly to get it to latch properly. We also can only lift up on the handle to unlatch it. It’s never concerned me, and has worked exactly the same way since new. Just wondering if this is something I should proactively tackle?
2011 FC 23FB
2012 Toyota Tundra Dbl Cab, 5.7 4x4
GettinAway is offline   Reply With Quote
Old 01-15-2019, 08:58 AM   #54
2019 30' Classic
Pleasant Garden , North Carolina
My 2019 Classic is the same way, you can only lift up on the handle. The door seems to close with out much effort but probably could be a little easier.
jlandreth is online now   Reply With Quote
Old 01-16-2019, 07:39 AM   #55
2018 30' Classic
Callao , Virginia
Rob
RFP, I'm not a metallurgist so I am guessing on the material. I did put a magnet on it and it acts like aluminum so you may be correct. Non the less it was a bad cast if nothing else and probably made in China. To get our door to close properly we need to give a pretty good tug on that handle and to me it's under engineered and doomed for failure.
HELP!!!! We got locked inside our Airstream JBBeaubeaux Doors & Locks 26 12-24-2015 06:07 AM
Dog locked inside trailer with the keys! Kristi Foster The Pet Forum 62 10-29-2013 09:32 PM
Door lock appears to be broken and locked from inside too! LucyPepper Doors & Locks 12 10-12-2009 11:20 PM
locked inside.. can't get out greenRNtrav. Doors & Locks 5 08-02-2009 10:51 PM
Walmart, Home Depot, Lowes....optional items for your Airstream leefields Ribs, Skins & Rivets 13 06-24-2006 03:02 AM
