Old 04-19-2012, 11:32 AM   #1
Great Bend , Kansas
list again lost other one. NEED HELP
I need to know what kind of wheels will fit on an airstream im going to pick up. Will it take a ford\dodge or chevy wheel.
dodgeman_197 is offline   Reply With Quote
Old 04-19-2012, 11:52 AM   #2
1976 31' Sovereign
Oswego , Illinois
Smile wheels forA.S.
A.S. uses 0 degree offset rims, I do not think they used any thing dif. as almost all trailers do, some of new A.S. use 14 inch wheels I pur. 15x6 6 lug aluminum wheels load rating 2830 lbs. from recstuff.com on line $78.40 ea. $25 ship.for 4 they have steel inserts in lug holes very nice most do not Cars trucks use various degree offset , will put wheel against skin
Old 04-19-2012, 11:57 AM   #3
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
The rims should be zero offset rated at 2600#. Automotive wheels are rated lower.
Old 04-19-2012, 12:09 PM   #4
AirsDream's Avatar
1999 23' Safari
Perrysburg , Ann Arbor
If you can get the trailer's VIN, a call to the Airstream factory can tell you exactly what sort of wheels it takes, and what is the GVW so you can figure out what tires to put on those wheels. Auto rims are pretty much a no-no on a trailer of any sort, Airstreams included. Pretty much any large trailer supply shop or Airstream dealer then can come up with wheels and/or tires or whatever else you need ... brake inspection / repair / adjustment? Bearings / seals? Electrical / brake hookup? etc.
AirsDream is offline   Reply With Quote
Old 04-19-2012, 12:12 PM   #5
None of the above.
Different years and different lengths, use different wheels.
What year and length are you picking up?
Old 04-19-2012, 12:14 PM   #6
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
Steel wheels can be bought from most any one dealing in trailer stuff.
They wheels on most Airstreams are 6 bolts on a 5.5? inch circle
The rims off older chevy 1/2 ton 4 wheel drive trucks are the right bolt pattern but the center hole is slightly small. Some of the drums have little "nubbins". The center of the rim can be heated at these points and hit with a hammer to expand it enough to go on.
That being said it really isn't worth the work.
The steel 6 bolt wheels you see on most trailers shouldn't cost more than 40 bucks each. They are marked 15x6 JJ and usually weight rated for 2600 lbs or so.
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 04-19-2012, 01:08 PM   #7
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Greetings Dodgeman_197!
Here is a link to your original thread.
http://www.airforums.com/forums/f161...elp-90027.html
Good luck with your retrieval trip!
Kevin
P.S.: You can always find any thread that you create or subscribe to by clicking on the tab labeled "User CP" at the top of the Forums page.
Kevin D. Allen
AIR #827
