Old 07-04-2013, 04:30 AM   #1
LuLuTravels's Avatar
Big Rock , Tennessee
Lights on the outside of airstream.
As a newbie to Airstreams we came to Elgin OK to get trailer. My husband had to replace umbilical cord. Hooked it up to truck yesterday and we have no lights . We are totally stumped. Can someone please shed some light for us?
LuLuTravels is offline   Reply With Quote
Old 07-04-2013, 05:00 AM   #2
AIR-Quarius's Avatar
1970 27' Overlander
Espanola , Full Timer
Send a message via Yahoo to AIR-Quarius Send a message via Skype™ to AIR-Quarius
Some one here in a minute will post a picture of the end plug to that cord...showing which port controls what on the Airstream. In your case - running lights. May have to go back and check it out more. good luck! Some time ago, I had just bought a new end plug replacement for our cord and it was not real easy hooking it up and connecting the right wires to the right ports, but one of these rocket scientist will chime in for you shortly.
http://customrvdecalplus.com
AIR-Quarius is offline   Reply With Quote
Old 07-04-2013, 05:11 AM   #3
LFC
Memphis , Tennessee
Might be as simple as cleaning out the truck end of things or wiggling on the plug.
In other words most likely just a bad or dirty connection.
LFC is offline   Reply With Quote
Old 07-04-2013, 05:12 AM   #4
Jimbcole's Avatar
1958 17' Pacer
Tryon , North Carolina
You mean this photo?
Jimbcole is offline   Reply With Quote
Old 07-04-2013, 06:14 AM   #5
bwoodtx's Avatar
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio , Texas
A 70's trailer is not wired the same as a current hook-up. You might have to re-wire according to the posted diagram.
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a good dog.
bwoodtx is offline   Reply With Quote
Old 07-04-2013, 06:54 AM   #6
Woodweavil7's Avatar
Southside , Tennessee
First all connections involved are brand new. Including the week old TV. I cut back the umbilical cord to the bulkhead and installed a female socket. Then used a replacement umbilical cord and added a male end to the other end. I called airstream technical and he walked me thru the conversion.
Woodweavil7 is offline   Reply With Quote
Old 07-04-2013, 07:12 AM   #7
Jimbcole's Avatar
1958 17' Pacer
Make sure you have power coming out of the TV connection first. Use a test light or volt meter if you have it. Turn the head lifts on in the TV with the ignition key on. Check to see of there is any voltage any where on your TV plug.
Old 07-04-2013, 07:14 AM   #8
Jimbcole's Avatar
1958 17' Pacer
Head lights not "head lifts"
Old 07-04-2013, 08:23 AM   #9
Tenkara Fly Angler
Big C's Avatar
1975 31' Sovereign
Vernon , Texas
Did you clean the pins the cord plugs into on the trailer?
1975 Sovereign
"The Silver Bullet"
2013 F350 Super Duty 6.7 Liter Diesel
WBCCI #8578
Big C is offline   Reply With Quote
Old 07-04-2013, 09:16 AM   #10
All new connections
Old 07-05-2013, 08:15 AM   #11
Jimbcole's Avatar
1958 17' Pacer
Did you find a solution?
Old 07-05-2013, 08:41 AM   #12
I'm having to replace all the lights. I'm hoping to utilize the 4" grommet mounted rounds that are readily available at most truck stops
Old 07-10-2013, 09:06 PM   #13
No not yet. Does the TT have to be connected to the TV ball hitch to complete the ground circuit?
Old 07-10-2013, 09:19 PM   #14
Jimbcole's Avatar
1958 17' Pacer
The white wire should be the ground. If that ground is not good you may need to be hooked up, or at least put the safety chain to the TV.
