Old 07-10-2013, 09:21 PM   #15
Tenkara Fly Angler
Big C's Avatar
1975 31' Sovereign
Vernon , Texas
Originally Posted by Woodweavil7 View Post
All new connections
so by new connections you mean new umbilical and new receptacle on the trailer? We had issues with lights and it was easily solved with a small wire brush when I cleaned the pins on the receptacle where it plugs in from the umbilical. Worked like a charm. Also had to clean all the contact points on the trailer lights.
1975 Sovereign
"The Silver Bullet"
2013 F350 Super Duty 6.7 Liter Diesel
WBCCI #8578
Big C is offline   Reply With Quote
Old 07-10-2013, 09:30 PM   #16
Woodweavil7's Avatar
Southside , Tennessee
Yes new umbilical cord and new recepticals. On TT &TV
Woodweavil7 is offline   Reply With Quote
Old 07-10-2013, 10:23 PM   #17
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Do not depend on the ball or safety chains for the ground/common side of the circuit.
You can test the lights on the coach using a battery charger. Connect the black lead of the charger to the frame of the coach in a clean shiny spot. Then test each of the remaining terminals on the plug in the side of the coach. Using the red lead of the charger.
Once you know the coach lights work. You can sort out how to match it up to the TV.
