Old 11-17-2015, 07:08 PM   #1
http://airstreamorama.com
Ljsydney's Avatar
2013 27' FB International
Palm Springs , California
Light's on at grey/black water tank outlet
Hello,
My light above the tank outlet has suddenly gone on (I didn't even know it was there!) and I can't switch it off! I've tried depressing the switch/button but it doesn't switch off. Is there a trick to this? I have a 2013 International Signature 27FB.
Appreciate all your advice!
John
Ljsydney is offline   Reply With Quote
Old 11-17-2015, 07:44 PM   #2
SSquared's Avatar
2013 25' FB Flying Cloud
Longmont , Colorado
Originally Posted by Ljsydney View Post
Hello,
John
No trick to it. Push On, Push Off.
I have a 2013 25FB and my switch has worked fine. It sounds like your switch has gone bad. The switch should give a good "click" when you press it, and you should feel the "click" as well.
SSquared is offline   Reply With Quote
Old 11-17-2015, 09:27 PM   #3
Ljsydney's Avatar
Thank you. Definitely here it click to no avail....
Old 11-18-2015, 03:49 AM   #4
Gainesville , Florida
Take the bulb out if you can.
Old 11-18-2015, 11:13 AM   #5
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Mine sometimes will not come on.
It works intermittently.
I've never had it stay on and not power off.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 11-18-2015, 07:28 PM   #6
Red C
2013 27' Flying Cloud
Idyllwild , California
We have a 2013 FC27. My light switch went bad last month. Bad switch fixed by replacing with a standard switch/wire assy (type available online for RV fans, etc.).
Access to the wiring requires removing the light, then switch, and re-splicing connections.
rgcorbett12 is offline   Reply With Quote
Repurpose black tank to grey tank The Rambler Waste Systems, Tanks & Totes 7 07-29-2015 10:10 PM
Replacing black water tank with grey water tank cheetah1 Sinks, Showers & Toilets 25 10-02-2014 05:26 AM
Black Tank, Grey Tank, New Tank, Old Tank Bunkroom Waste Systems, Tanks & Totes 3 07-22-2014 08:35 PM
VTS Vintage Grey Tank for Black Tank? bluemoontwo Waste Systems, Tanks & Totes 1 11-27-2012 08:03 AM
Replacing black/grey with a larger grey whitney Waste Systems, Tanks & Totes 11 05-08-2012 06:47 PM
