Old 02-10-2016, 02:40 PM   #1
PSU1981
PSU1981's Avatar
2015 27' Flying Cloud
Spring , Texas
Lights Not working in hood over stove
While camping this past weekend both lights quit working over the stove? Find it kinda hard both burned out same time. Any ideas?
PSU1981
2015 27FB Flying Cloud
Spring, Tx
PSU1981 is offline   Reply With Quote
Old 02-10-2016, 02:49 PM   #2
2015 30' Classic
Pleasanton , California
Did the fan stop working too?
I had an issue where the plastic slide piece that you move to turn on and off the lights separated from the actual switch causing the same symptoms. I simply had the dealer repair it.
Al, K6IV
2015 30' Classic, "Chez Nu"
2014 RAM 2500 w/Cummins Diesel
ProPride Hitch, 400 W Solar
alano is offline   Reply With Quote
Old 02-10-2016, 02:50 PM   #3
2007 22' International CCD
Actually it's possible both bulbs went out at the same time. Or the switch went out
First thing to check: Still have power to the fan in the hood?
Then check bulbs with a VOM, then use VOM to look for power on the bulb sockets.
That should get you there.
Old 02-11-2016, 08:26 AM   #4
PSU1981
PSU1981's Avatar
Spring , Texas
Fan still works
Old 02-11-2016, 08:28 AM   #5
PSU1981
PSU1981's Avatar
Spring , Texas
What is a VOM - volt meter?
How do I use it?
Old 02-11-2016, 08:40 AM   #6
2015 30' Classic
VOM stands for Volt Ohm Meter. Select DC volts and insert each probe into each lamp receptacle. If you measure approximately 12 V then you know your bulbs are bad. If you measure 0 V, then you should take your 2015 back to the dealer for service.
Al, K6IV
Old 02-11-2016, 09:46 AM   #7
PSU1981
PSU1981's Avatar
Spring , Texas
Ok - thanks!!!
Old 02-11-2016, 09:59 AM   #8
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
There is also a separate inline fuse in the fan assembly. Not sure it if protects only the lights or the fan as well but you might want to look at that before you get to the more complicated diagnostics.
Bob Martel
WBCCI# 5766
Old 02-11-2016, 10:04 AM   #9
Chelsea , Michigan
Images: 12
Range Exhaust fuse
The fuse can be accessed under the grease screen. It's in that little black box at the back of the compartment. It's behind the small round black cover. As I said earlier, I'm not sure if the fuse protects the lights only or the fan as well. Since your fan works, this may not be the culprit but it's easy enough to check.
Bob Martel
WBCCI# 5766
Old 02-11-2016, 10:23 AM   #10
2015 30' Classic
If you do find out your bulbs are bad, consider changing them with LED replacements from LED4RV.com. Seems quite wasteful that AS didn't fit these with LEDs as well.
Al, K6IV
Old 02-11-2016, 10:38 AM   #11
1972 31' Sovereign
Huntley , Montana
PSU1981, Your AS is much newer than mine so what I have to suggest may be worth nothing. I had the same problem in my '72 Sovereign. When I discovered that the light over my sink stopped working and bulb replacement didn't solve the problem, I assumed there was a broken wire somewhere inside the interior wall of the unit. Not wanting to trace that out, I got the idea of splicing into the wire for the exhaust fan which did work. That solved my problem although it may not be the solution for yours. Anyway, for what it is worth......
Philip498 is offline   Reply With Quote
Old 02-11-2016, 10:57 AM   #12
interstateflyer's Avatar
2017 25' International
Los Osos , California
Our 2014 International's fan was DOA from the factory. They'd forgotten to install the fuse.
2017 Airstream International Serenity 25FB
2016 RAM 2500 Crew Cab Cummins 6.7 Diesel
interstateflyer is offline   Reply With Quote
Old 02-11-2016, 11:56 AM   #13
shadedsilver
2014 27' FB International
Bisbee , Arizona
Both our hood lights burned out at same time in our 2014. The dealer replaced them under warranty.
shadedsilver is offline   Reply With Quote
Old 02-11-2016, 01:58 PM   #14
PSU1981
PSU1981's Avatar
Spring , Texas
Thanks everyone. Does anyone know if the inline fuse is for both the fan & the lights?
Why not LED lights in the stove hood? LivLoveLaugh Lights - Interior & Exterior 34 08-13-2017 09:39 AM
Stove Hood Lights Burned Out Ljsydney Stoves, Ovens & Microwaves 2 04-14-2015 09:32 AM
Over the stove vent and light hood DJW General Interior Topics 1 06-04-2014 08:46 AM
Range hood fan not working Natestravels Stoves, Ovens & Microwaves 5 03-22-2014 01:03 PM
Hood/hood lights and water heater stopped working!!! Thomas_G Electrical - Systems, Generators, Batteries & Solar 1 06-17-2013 12:49 PM
