Old 03-18-2012, 04:51 AM   #1
thunderbird's Avatar
1968 26' Overlander
Spijkenisse , netherlands
LED lights for '68 AS
anyone knows what LEDs to use in a68 airstream ? I want to replace the STTlights (stop/turn/tail) . there are Grote lights mounted now and I think OEM . what is the replacement?
thanks in advance.
regards George
thunderbird is offline   Reply With Quote
Old 03-23-2012, 03:40 PM   #2
1968 26' Overlander
anyone????
Old 03-23-2012, 03:45 PM   #3
Full Time Alumaloafer
louaxtjr's Avatar
1966 24' Tradewind
Livingston , Texas
Images: 12
Check the bulbs in your current stt assemblies. Then google the bulb number and "led" as there are many sellers of direct replacement led bulbs.
Lou
Lou Axt, Jr.
1966 Tradewind
1969 Chevy C10
_____________
Phillipians 4:13
louaxtjr is offline   Reply With Quote
Old 03-23-2012, 06:27 PM   #4
65CV's Avatar
Western , Massachusetts
Many people like this site
LED Lights, Bulbs & Accessories - SUPER BRIGHT LEDS
65CV is offline   Reply With Quote
Old 03-26-2012, 10:43 AM   #5
Dan@LED4RV's Avatar
Denton , North Carolina
Don't Use cluster bulbs
thanks in advance.
regards George
The cluster bulbs don't work so well. Below is the reason why.
One of the main reasons why cluster bulbs don't work well is they produce about 1/3 as much light if the cluster bulb is about the same size as the incandescent bulb your replacing. The other reason is most of the STT fixtures are designed to refract and reflect light from one single location.
Below are two pictures which have a STT light and some markings that illustrate what happens when you use a cluster bulb in some STT lights.
The little blue marks on the red lens are to show how the lens is designed to refract light.
On the next picture ( below) is what a cluster bulb looks like ( as crude as it is :-) in the same light fixture.
Many points of light being refracted and reflected has a result of the light going in many different directions. In the event that your cluster bulb was to produce more light (they seldom do) than the incandescent bulb, it would not be as effective ( and safe) because the light does not all show up at the intended target, the guy behind you.
A pad type array is what will give more light. Most cars that have LEDs are designed where the light is projected in one direction which is out the back.
We are very close to having a light that does just that for the 65 to the first half of 74 Airstreams. In other words the round Lens now made by Grote. I will post back to this thread when we do.
Dan Brown
Denton NC
Dan@LED4RV is offline   Reply With Quote
Old 03-26-2012, 11:59 AM   #6
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
Dan
Thanks for the education about why cluster bulbs do not work so well in this application.
Dan
Old 03-26-2012, 12:01 PM   #7
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
George
Is there a reason why you want to change your exterior lights to LED lights? Just curious.
Dan
Old 03-26-2012, 12:14 PM   #8
1965 22' Safari
East Islip , New York
Originally Posted by TouringDan View Post
George
Dan
If done right they give better light, lower power requirements, and better reliability.
That's assuming you're using good units. Bad ones don't give you any of the above.
-Hans
HHaase is offline   Reply With Quote
Old 03-26-2012, 06:25 PM   #9
Rob&Julie's Avatar
1988 32' Excella
Bonny River , New Brunswick
Images: 16
thanks in advance.
regards George
Does the 68 take the 4.25" Monarch style STT lights? If so, I saw this led kit just yesterday. The LED panel has a bulb base/screw that fits the original socket...it's a bit pricey though.
Sealed LED light kit for old 4.25 Monarch LED-kit2 [LED-kit2] - $169.95 : LEDs 4, Recreational Vehicles
Rob&Julie is offline   Reply With Quote
Old 03-27-2012, 03:14 PM   #10
1968 26' Overlander
the reason I want to change to LED is that they are so much brighter and I once had a jerk jam into my rearbumper
I will wait for the new lights to come out.
thanks
regards George
Old 04-01-2012, 06:06 PM   #11
1965 22' Safari
thanks
regards George
Does your existing housing have a reflector in it? Or is the existing reflector dingy and dirty? If not, you can also spray the inside of the housing with a bright silver paint. This really does help a lot for making tail lights more efficient, and puts more light out the lens.
Here in the USA, most auto parts stores carry some kind of 'bumper chrome' style paint. These are the best choices, as they are the most reflective.
-Hans
Old 04-01-2012, 06:52 PM   #12
Tool Hoarder
West , California
Inland RV has some nice ones these should match exactly.
marzboy is offline   Reply With Quote
Old 04-02-2012, 06:30 AM   #13
Dan@LED4RV's Avatar
There are a few
George
Dan
Just like -Hans said, If done right
they give better light,>>>>>> Like the reason I stated above with the tail lights they do give better light. For the running lights and the STT (Stop, Tail, and Turn) the LED are spread out and are very bright. That makes you much more visible on the roads at night.
lower power requirements, >>>>>> As units get older there are a number of reasons why the " running lights and the STT lights" are not as bright as they were when they were new. Corrosion in the light fixture at the bulb contacts, and the inside of the fixtures as well as poor contacts on the wires inside of the unit are a few. With LED lights, the lower power draw allows you to get past much of the reasons listed here.
and better reliability>>>>>>> LEDs last much longer, and in the event you do have a failure on a single LED you will still have plenty of light un-like with a single filament incandescent bulb. If that single filament goes out, you have no light. That is a biggie when your on the road at night.
For the most part, the main reason why one would want to go to LED lights for their " running lights and the STT lights" is safety.
Dan Brown
Denton NC
Old 04-02-2012, 06:34 AM   #14
Dan@LED4RV's Avatar
No
No the LED-kit2 will NOT work in a 1968. We hope to have one real soon that will allow a very quick and easy install. I will post back to this thread when we do. Thank you for asking.
Dan Brown
Denton NC
Looking for work campers in central TX scorpiontimo Working on the Road 3 06-12-2015 12:16 PM
LED lights for '68 AS thunderbird General Repair Forum 18 04-09-2012 11:52 AM
drying rack for 2007 Safari 25' jetjocky Off Topic Forum 2 03-24-2012 11:55 AM
Vulkem 116 and Acryl-R, which do I use for what? Sandi & Bob Leaks - Weatherstrips, Gaskets, Caulks & Sealants 20 03-24-2012 09:00 AM
NY State said no to a vintage plate, Time for a letter campaign. HHaase Airstream Lifestyle 14 03-23-2012 10:30 AM
