Old 09-05-2018, 06:35 AM   #1
2018 25' Flying Cloud
Smyrna , Georgia
Led ceiling lights stopped working
The led ceiling lights in the rear of my 2018 25ft Flying Cloud have stopped working.
All fuses have been checked and are ok.
Any suggestions before returning to dealer?
DKGA is offline   Reply With Quote
Old 09-05-2018, 07:31 AM   #2
sb55's Avatar
2018 30' Flying Cloud
South Hero , Vermont
Mine too on a 2018 30 FC. Plus my shower fan. Still havenít found a solution
sb55 is offline   Reply With Quote
Old 09-05-2018, 07:47 AM   #3
ShullsinUtah's Avatar
Draper , Utah
Are the wires connected at the back side of the fuse panel? (Are you getting 12 volts at the lights?)
ShullsinUtah is offline   Reply With Quote
Old 09-05-2018, 12:55 PM   #4
Airstream Ambassador
AirstreamInc's Avatar
Jackson Center , Ohio
Hi DKGA and sb55,
We're very sorry to learn about the issue you are having. Please send us a direct message with your contact information and the last 6 digits of your VIN so we can share it with our Customer Service and Technical Support team. We look forward to helping you get this resolved.
You can also reach Airstream Customer Service and Technical Support at customer_support@airstream.com
Thank you.
Official account for Airstream, Inc.
Airstream Customer Service and Technical Support can be reached at 1 (877) 596-6111, option 1.
AirstreamInc is offline   Reply With Quote
Old 09-09-2018, 03:00 PM   #5
Smyrna , Georgia
I removed the light switch and found an inline fuse inside the wall. I replaced the blowed fuse and now the lights work.
Old 11-15-2018, 07:40 PM   #6
2018 30' International
Cary , North Carolina
Similar Issue - Rear Bedroom Overhead Lights on Dimmer not working.
I'm curious where you found the inline fuse. Our dimmer & on / off switch is mounted on the wardrobe (Serenity 30BRT).
Thanks.
TMoose is offline   Reply With Quote
Old 12-25-2018, 05:22 PM   #7
DoublTrouble's Avatar
2015 27' FB International
Carlsbad , California
remove the trim(pop it off) maybe finger nails or carefully with a tool...
3 or 4 screws underneath the trim. gently pull wires out...inline fuse holder there...blade automotive type...
10 amp. I think...
DoublTrouble is offline   Reply With Quote
Old 06-17-2019, 05:48 PM   #8
Kensington , Maryland
10 amp. I think...
Same issue here. I also replaced the fuse however it popped. I'm going to begin removing LED fixtures and testing for a short.
2017 25' FC FB "Buck"
Subforum dedicated to Airstreams and riding bicycles:
https://www.velocipedesalon.com/forum/f62/
Too tall is offline   Reply With Quote
Old 06-18-2019, 04:39 AM   #9
Smyrna , Georgia
After several blown fuses I found the round head screw next to light switch that holds the cabinet in place was rubbing against the light /dimmer switch causing a short. I removed the screw, counter sunk the hole, replaced the round head screw with a flat head. Now the metal screw cannot touch the switch and cause a short. I also replaced the switch.
Old 06-18-2019, 04:45 AM   #10
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
Good!
Glad you found it! More quality builds from Airstream!!
Larry
lsbrodsky is online now   Reply With Quote
Old 06-18-2019, 10:14 AM   #11
Dropped all the lights. Did not find a short. Traced the power leds from the dimmer and find nothing unusual.
Hmmm
Old 06-21-2019, 08:50 AM   #12
Too Tall, our issue still remains a mystery. Initially we suspected a worn wire (purple or white) maybe grounding out between panels. Or maybe a missing grommet. We bench tested the lights with the switch and all was fine. After replacing the dimmer switch several times, the thing started behaving and has worked steadily for a year. It is still an unsolved mystery.
The 3rd switch was the charm?
Old 06-22-2019, 04:38 AM   #13
That is helpful. My issue does not appear to be poor ground or a short OR a bad fixture. For $40 I'm going to order a replacement dimmer so that I have one to test against and a potential fix.
For others reading, I believe this is the correct part:
https://pdxrvwholesale.com/products/...-ah-sld-5-hs01
Old 06-30-2019, 05:36 PM   #14
Fingers crossed, it's solved. I installed the (above) listed replacement dimmer and downgraded the fuse to 6.5 amp and the lights are on for the last 3 hrs.
Bad dimmer!!!
1976 Argosy:Interior overhead front lights stopped working Wanderingjee General Repair Forum 0 07-30-2014 11:59 PM
Hood/hood lights and water heater stopped working!!! Thomas_G Electrical - Systems, Generators, Batteries & Solar 1 06-17-2013 12:49 PM
LED Lights Mysteriously Stopped Working LiLNomad Lights - Interior & Exterior 3 10-28-2012 02:16 PM
Interior 12V lights stopped working~Help! RonB Lights - Interior & Exterior 3 08-16-2012 09:20 AM
Tail Lights Stopped Working dpope 2003 Safari 8 04-05-2003 12:22 PM
