Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > General Repair Forum
Old 10-02-2002, 06:19 PM   #1
Just a member
thenewkid64's Avatar
Profile:  Tampa Bay , Florida
Images: 21
Talking Least expensive repair
Tonight I tackled a task that has needed doing since I bought my motorhome last spring. The oil seal on the curbside rear axle has been dripping(very slowly) gear oil and making a mess on the wheel, not to mention the smell. I assumed it was going to be a difficult fix, I was suprised. The PO had used some type of gasket in a tube to seal this when he put it back together after doing the rear brakes. I pulled the plate and cleaned the gasket goop off, and tried to reinstall without any gasket. (Peter, there were no ridges??) Still leaks, so I went to the Auto parts store and got a $4.59 roll of gasket material and cut one to fit and installed it. (Fred, add this one to your list) No more leak and the greasy wheel is now clean and shiney!
The jist of this is that so far this has been the leat expensive repair to date! We all try to get a good deal, so lets compare notes. What has been the least expensive repair that you have done/had done that you thought was going to be difficult or big $$.
This is not a contest so I declare light bulb replacement a waste of bandwidth
Brett G
WBCCI #5501 AIR # 49
Logic is the one way you can go wrong with confidence - Charles E. Kettering
Old 10-02-2002, 06:27 PM   #2
gwsullivan's Avatar
Profile:
My black tank valve gate leaked. I tried soaking it with water and chemicals. I tried back flushing it. Nothing seemed to work so I decided to replace the valve. Well, I went to this rally and they were selling something called a "Flush King" which attaches to the valve and basically back flushes with pressure. End of problem. Thirty some dollars and 5 minutes labor.
Jerry Sullivan
'01 Limited
'01 Safari
On The Road, USA
gwsullivan is offline   Reply With Quote
Old 10-03-2002, 08:26 AM   #3
Profile:  LOST , Hawaii
Does a toad count?
Coming across Nebraska last summer with a '91 Geo Metro in tow. The road had very rough expansion joints. I stopped to eat, went back to the Geo and opened the driver's door, it dropped about 4 inches. I knew the pins were going but the hammering finished them.
When I got back I was going to replace them, but they were not available at the parts stores. The dealer sold new hinge assemblies at $80 each. Pulled the pins, welded them and turned them down on the lathe. Figured I saved $160 for an hours labor and some electricity.
John
74Argosy24MH is offline   Reply With Quote
Alternate exterior plastic parts repair IPM Bumpers & Bumper Storage 2 01-24-2008 11:46 AM
Frame Repair greg176 Repairing/Replacing Floor &/or Frame 40 07-29-2004 10:05 PM
Floor Repair 1967 Caravel bpaolini Repairing/Replacing Floor &/or Frame 0 08-04-2003 10:43 AM
Front Wing Window Repair Charles D. Bennett Windows & Screens 0 08-10-2002 07:04 PM
