Old 12-25-2015, 05:46 AM   #1
parzam21's Avatar
Newport Beach , California
LEAKS LEAKS more LEAKS in ATL
Just drove in to Atlanta during monsoon season with a 2009 FC. I'll be here for the next 3 months for school.
To my dismay, I have multiple leaks. I'm counting at least 6. One from each ceiling fans; one from bathroom vent; and 3 from ceiling over bed.
I'm assuming these are all coming from poor sealing around the fans.
Any suggestions or referrals much appreciated and needed.
Happy Holidays
parzam21 is offline   Reply With Quote
Old 12-25-2015, 05:50 AM   #2
Gainesville , Florida
Eternabond tape if it ever dries out.
Old 12-25-2015, 07:45 AM   #3
1987 Avion 34W owner
PaulnGina's Avatar
Good Ol' , USA
x2 on the Eternabond AlumiBond tape.
https://www.bigrocksupply.com/store/...n-x-50-ft.aspx
“What’s good for me may not be good for the weak minded.”
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
PaulnGina is offline   Reply With Quote
Old 12-25-2015, 09:18 PM   #4
1990 32' Excella
jonesboro , Arkansas
I use vulkem polyurethane caulk. Comes in grey. Get up top and check all the seams around fans and all vents.(do every year at least) also check the seals under the vent lids and make sure they are shutting all the way.
joel is offline   Reply With Quote
Old 12-25-2015, 09:29 PM   #5
PaulnGina's Avatar
Good Ol' , USA
On all of our Avion's roof seams, after I cleaned them well, including removing all of the old sealant in the seams and around the vents, I applied a bead of ParBond in the seam, let it dry a bit, then covered the seams with the EternaBond AlumiBond 4" tape. The thing I liked about doing it this way is that once it's done, you can forget it for a long time. A yearly check of things is about all that's needed.
With good prep, that tape will stick and probably outlast you!
PaulnGina
1987 Avion 34W
Blessed and highly favored
1987 Avion 34W
Old 12-26-2015, 07:55 AM   #6
lewster's Avatar
Naples, FL , Hood River, OR
I hate to be a contrarian, but from my professional experience over the last 15 years, using Eternabond tape for a leak is like placing a Band-Aid over a wound that requires stitches. I have been called many times to correct leaks that were 'sealed' with Eternabond, only to start peeling and leaking in relatively short order………even those that have been properly prepped and sealed with a roller.
There are far better, more permanent solutions to solving leak problems, and these have been discussed at length in a sealant thread. Of course, as always…………YMMV!!!
In fact, I was just doing some re-organizing in my shop and found several rolls of the stuff……….all available at great prices!!!!
PM me for further information.
Old 12-26-2015, 08:57 AM   #7
We will have to agree to disagree on this one.
Old 12-26-2015, 09:03 AM   #8
PaulnGina's Avatar
Good Ol' , USA
Prep is the key, as with anything that you want to adhere well.
How can you tell if something was prepped properly if you are coming in after the fact to fix it?
PaulnGina
1987 Avion 34W
1987 Avion 34W
Old 12-26-2015, 10:28 AM   #9
LABTOPIA
labtopia's Avatar
1958 22' Caravanner
Atlanta , Georgia
Originally Posted by parzam21 View Post
Just drove in to Atlanta during monsoon season To my dismay, I have multiple leaks. I'm counting at least 6. One from each ceiling fans; one from bathroom vent; and 3 from ceiling over bed.
Happy Holidays
DUDE! I'm full timing in my '58 Caravanner in ATL and have found a few leaks again after this weeks ridiculous rain here too. All of them are from the dude that rebuilt this trailer & he sealed all this leaking stuff with a bunch of silicone...it's a process to get this junk off and reseal correctly with c-10 or vulkem...I've knocked them out one by one but always have to wait for things to dry out and clean the areas well before applying new sealant. I've used butyl tape as a temp quick fix if its still raining...
Dave Ballard - Full Time Airstreamer WBCCI #4276
http://180sqft.drinkertoys.com/ READ MY AIRSTREAM BLOG
Electric Unicycle Rider (SBU)
labtopia is offline   Reply With Quote
Old 12-26-2015, 02:15 PM   #10
1978 Argosy Minuet 6.7 Metre
1971 27' Overlander
1973 31' Sovereign
Griffin , Georgia
Images: 14
Where in atlanta? I have great repair guy on the south side.
paddle whisp is offline   Reply With Quote
Old 12-26-2015, 03:18 PM   #11
2018 25' Flying Cloud
Mission , Texas
We had to replace our fan because the plastic frame had many hairline cracks. Also had the bathroom vent sealed.
ghamr is offline   Reply With Quote
Old 12-27-2015, 05:34 AM   #12
Kathys quilt's Avatar
1967 30' Sovereign
Nauvoo , Alabama
AGREE - never ever put that #@^$ tape on your trailer - you will regret it or the next owner will! This rain is not the norm for the SE. I thought I had all my leaks fixed on my 67 but this rain found some more. If you are comfortable doing the work take and do the work. Temp fix for small leaks is creeping crack filler from VTS. NO SILICONE as stated above. You have about 24 hours with no rain ahead. Duct tape areas for temp stoppage It will remove easily enough. Remove all old sealants before applying new for sealant on sealant most often fails - But as someone in school as I was four 5 summers at Emory, I hope you have the time to DIY. Best of luck on school and the normal for course, leaks in an older AS.
To all who served - give them thanks - give them respect - may God give all many blessings (Ray Bozeman)
Kathys quilt is offline   Reply With Quote
Old 12-27-2015, 07:48 AM   #13
parzam21's Avatar
Thank you all for your the great advice as usual. However, I think the problem maybe well above my expertise and pay grade. I went to Home Depot and bought some aluminum tape in the Interem to tape around fans, which helped. However, I'm getting leaks from the seams as well. I have a feeling I'm going to need prose sealing and I'm 3000 miles away from home.
Any good suggestions to repairs facility or mobile guy in ATL?
Old 12-27-2015, 07:50 AM   #14
parzam21's Avatar
Would greatly appreciate his contact info. Is he a mobile repair guy?
Leaks, leaks, and more leaks da_lizard Leaks - Weatherstrips, Gaskets, Caulks & Sealants 15 04-11-2016 11:36 AM
new dealer in ATL RamblinManGa Airstream Lifestyle 1 10-18-2015 11:13 AM
recommend great spot in SW GA or ATL? kstampa On The Road... 11 05-14-2008 06:53 PM
Leaks, Leaks and more leaks Jim in Pima Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 12-12-2007 11:23 AM
A/S serial # 434 in ATL tod47d Mechanics Corner - Engines, Transmission & More... 0 01-25-2003 08:44 PM
