Old 01-13-2020, 02:26 AM   #1
Leaks in the back end!
So I was looking to see if I could add some USB power plugs to the cabinet above my bed. Tracing some wires I felt sopping wet insulation on the right side(street side). It extends as far as I could reach above the shower. Rigged a fan to hopefully dry things out. Suspected sources red lights up top, bath fan, fantastic fan. Havenít removed anything else to see if I can find more wet insulation. (Itís midnight now)
Will be calling Airstream in the morning. Any suggestions as to what I could or should do?
19í international serenity 2014
eagle5 is offline   Reply With Quote
Old 01-13-2020, 07:26 AM   #2
CRH
1995 25' Excella
xxxxx , xxxxxx
I had a leaky Fantasic fan due to cracks in the outer frame. I pulled the inner frame and waited on a heavy rain. I could see it leaking.
CRH is offline   Reply With Quote
Old 01-13-2020, 07:47 AM   #3
Overkill Specialist
GMFL's Avatar
2014 23' International
Dadeville , Alabama
Usual suspects are clearance light, fantastic fan, or bath fan.
Have you ever resealed your roof? If not it’s way past due for a reseal.
Old 01-13-2020, 10:06 AM   #4
Have you ever resealed your roof? If not itís way past due for a reseal.[/QUOTE]
Thanks!
That was supposed to have been done when I bought it used last year. Guess Iíll add it to the list of reasons to never do business with that Bay Area dealer again....
Thinking Iíll go full redneck style and throw a blue tarp over it till I can get it in for repairs.
Old 01-13-2020, 10:49 AM   #5
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Bad idea, it will scratch your clearcoat. You can make a cleanable mess if you use aluminum tape or even duct tape over the suspicious areas, or better yet, take it to a shop that can pressure test for leaks and get the the leaks you haven't yet found as well as this one.
Tape gunk comes off with mineral spirits patience and many rags.
Old 01-13-2020, 11:02 AM   #6
AirMiles's Avatar
2018 27' Globetrotter
Apollo Beach , Florida
I'd say check the black and grey tank vents. This is a very common roof leak. See this thread: http://www.airforums.com/forums/f456...in-200768.html
I fixed this problem by adding 4" sewer caps over the vents. You could buy these sewer caps and place them over your tank vents to see if that stops the leaks. Then you can decide whether to just permanently glue them on like I did (pic: http://www.airforums.com/forums/f456...ml#post2288568 ) or remove the vents, repair, and reinstall them.
2018 Globetrotter 27Q, 32 nights 4,935 miles, 600W Solar, PD4655L, 6V Batteries, ProPride, 16" Michelin's, 2019 F250 PSD
Sold: 2017 Flying Cloud 25FB, 316 nights 40,150 miles, 400W Solar
Sold: 2013 Casita SD17 89 nights 16,200 miles
Solar Production: 213 kWh in 248 days of use
AirMiles is offline   Reply With Quote
Old 01-13-2020, 09:01 PM   #7
Tank vents are a bit forward of where it was leaking,
Tore apart the fans and found them dry. Primary culprit seems to be the clearance lights and a mystery hole with a plug just aft of the center clearance light. Hopefully get some pictures tomorrow. Never looked to close at them, someone did a �� job installing them ��
Old 01-14-2020, 12:06 PM   #8
2005 19' Safari
2007 23' Safari SE
Onekama , Michigan
The mystery plug aft of center light is more than likely from the PO's rear facing camera he took off before he sold it to you.
Gene T is offline   Reply With Quote
Old 01-14-2020, 07:48 PM   #9
jamieb1086's Avatar
2016 25' Flying Cloud
Selbyville , Delaware
Have a backup camera ? The one leak I’ve had came from improper sealing when the camera was installed. If you have one, check its sealant too.
Jamie
2016 25' RBT Flying Cloud "Bullseye"
2016 Chevy 2500 High Country Duramax Diesel "Red Bull"
WBCCI #9026 Watchung NJ Unit
jamieb1086 is offline   Reply With Quote
Old 01-14-2020, 09:40 PM   #10
2017 28' International
Baileys Harbor , Wisconsin
Might want to check the outside seals of the aluminum. I had a leak in the back, and when I examined it there was a seam that wasn’t sealed very well. I sealed it, and no leak.
Daquenzer is offline   Reply With Quote
Leaks, leaks, and more leaks da_lizard Leaks - Weatherstrips, Gaskets, Caulks & Sealants 15 04-11-2016 12:36 PM
LEAKS LEAKS more LEAKS in ATL parzam21 General Repair Forum 17 12-27-2015 03:46 PM
Leaks, Leaks and more leaks Jim in Pima Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 12-12-2007 12:23 PM
Leaks, leaks, leaks jeffnjen30 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 8 08-28-2007 12:03 AM
leaks leaks leaks Globie64 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 10 12-31-2005 06:49 PM
