Old 06-14-2015, 09:27 AM   #1
2014 23' Flying Cloud
Rhinebeck , New York
Leaking Water Pump
Dear friends,
I just completed the de-winterizing process on our 23' International Serenity (rear bed model). All systems seemed to be working until I noticed water around the shower base which lead to discovering a leaking water pump. Air/water was leaking from what might be a front end seal(??). The round front of the unit seems to engage the main body held in place by several screws…….some not visible; perhaps a seal is installed there?? The space available for any repair work is too small for a novice mechanic like me so I suspect it will be trip to an RV repair facility. Any experience repairing water pumps on the 23' Serenity or like models?? Worth attempting a home repair or just bring it to a shop. The cost for the repair is not really an issue. Thanks to all.
Adam Geuss is offline   Reply With Quote
Old 06-14-2015, 10:08 AM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Mine was leaking in that area. 4 screws to pull the pump. I replaced 2 o-rings in the back end and 1 on the intake hose. Nothing special about the o-rings. You can match them at Lowe's for under a dollar for all. The back mounting screws may be blind mounted. You can reach around and feel their location.
MICHAEL
Old 06-14-2015, 05:46 PM   #3
Thanks for the response. Finding folk in similar circumstances especially those having made the "fix," is encouraging. Too bad Biloxi is so far away! I will have another look at my pump in the morning. The compartment in which it is installed is very small and packed with hoses and cabling that getting at the screws to get the pump out seems daunting. I certainly will try. Repairing the pump vs having it repaired for me will be an accomplishment. Wish me luck. Oh, I'm retired an d have no excuses with regard to available time.
Old 06-17-2015, 04:04 PM   #4
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
Sometimes the hassle of rebuilding the pump with new seals isn't worth the effort. Mine is a simple pump, so I have made it a policy to always have a spare, and it is kept, wrapped in a plastic bag, beside the working pump. On sale, the pumps can be had for about $100 on Amazon.
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
blkmagikca is offline   Reply With Quote
Hooked up water in winter and can't get water pump to pump water mrpettit Water Heaters, Filters & Pumps 8 05-06-2015 06:46 PM
Water pump leaking - 2006 Classic mkdaily3 Water Heaters, Filters & Pumps 3 08-01-2014 05:45 PM
Water pump leaking - repair or buy new? Doug C Water Heaters, Filters & Pumps 2 04-29-2014 07:49 PM
Water pump leaking between head and motor Ezmoneybcs Water Heaters, Filters & Pumps 4 03-20-2011 06:32 AM
68 water pump-should the pump cycle? Boondocker Water Heaters, Filters & Pumps 8 08-06-2006 10:11 AM
