Old 09-19-2016, 11:24 AM   #1
1973 Argosy 26
dawsonville , Georgia
Leaking A/C
Any suggestions on how best to address a leak around the base of the A/C? I have a 73 Argosy with what may...or may not be...an original A/C roof unit. There is no shroud on it.
I have never had an issue with light to moderate rain, but when it rains heavily, there is a fairly steady drip from the unit into the cabin. Yesterday while getting some much-needed rain in Georgia, I had a substantial leak and took the interior base off the unit. to try to discover the source. The water appears to be coming in around the bottom of what I assume is some sort of rubber seal (not coming in through the air flow tunnel or the actual unit) Should I seal inside around the existing seal, or attempt to remove the entire unit and reseal or try to seal from the roof?
The A/C works great.
Thank you in advance.
Cleosdad is offline   Reply With Quote
Old 09-19-2016, 11:44 AM   #2
SteveH's Avatar
Common Sense , Texas
The A/C unit has a foam seal between the unit and the roof of the trailer. To replace that seal the A/C unit has to be lifted off the trailer. Not a big deal, but more than one handyman can do at home.
Regards,
Steve
Propane leaking -- not leaking StreaminGeo LP Gas, Piping, Tanks & Regulators 8 07-26-2016 11:38 AM
HELP fresh water tank leaking wvabeer Fresh Water Systems 2 04-08-2003 11:10 AM
Safari roof still leaking Raptorrider2001 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 9 03-04-2003 11:32 AM
leaking around front window of 1969 Caravel David Henderson Leaks - Weatherstrips, Gaskets, Caulks & Sealants 0 10-27-2002 11:01 AM
Is my commode leaking? Fooltime Sinks, Showers & Toilets 5 04-16-2002 09:24 AM
