Old 02-08-2016, 03:59 PM   #1
Brookings , Oregon
Leak in front window.
My front window track fills with water during a rain. I just used Captain Tullies crack seal on all the rivets but noticed that there are several holes above the window (from former screws?) where the water may be coming in. What is a good product to fill those holes with?
aquadogs is offline   Reply With Quote
Old 02-08-2016, 11:34 PM   #2
Pygmypoacher's Avatar
Black Diamond , Washington
Are you missing any AIRSTREAM letters? Shouldn't be any random holes.
Pygmypoacher is offline   Reply With Quote
Old 02-09-2016, 01:04 AM   #3
CRH
1995 25' Excella
xxxxx , xxxxxx
I would fill the holes with Parabond or Vulkem.
CRH is offline   Reply With Quote
Old 02-09-2016, 08:34 AM   #4
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
Did you check the window seals?
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
blkmagikca is offline   Reply With Quote
Old 02-09-2016, 08:54 AM   #5
Those holes may have been from a front window rockguard.
You can install Olympic rivets in those holes, with a little sealer on the backside of the rivet head.
That would not be as obvious as spots of sealer.
Old 02-09-2016, 11:13 AM   #6
Regular Guy
NavyCorpsman's Avatar
1978 31' Sovereign
Hot Springs , Arkansas
can you use a rivet? There was a hole in my coach that the PO covered with a small aluminum plate and a couple of rivets. It looks like a patch but isn't obnoxious. vulkem would be my 2nd choice.
NavyCorpsman is offline   Reply With Quote
Old 02-09-2016, 01:31 PM   #7
2009 27' FB Classic
Cincinnnati , Ohio
Be careful. We had the same thing and had Airstream fix the leak. We just took our unit in a few weeks ago to get the dinette area redone and they found major damage under one of the seats in the dinette area where it had been leaking for quite some time.
KathleenBenk is offline   Reply With Quote
Old 02-09-2016, 02:54 PM   #8
Cedar Falls , Iowa
If you are able to fill the holes first and then apply a small amount of sealant on each rivet or screw, that might take care of it. Never use an excessive amount of sealant both for looks and easier tracking if the leaks continue. I would use silver Ten-X or similar
Ace RV is offline   Reply With Quote
28 FC front window rock guard front center window dayner Windows, Doors, Locks & Vents 0 08-29-2015 06:41 PM
Front window leak fix? BarnacleBill Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 7 01-18-2011 05:04 PM
Leak in 2008 27 FB SE near Front Window Shepstream Leaks - Weatherstrips, Gaskets, Caulks & Sealants 14 06-29-2009 06:42 PM
Leak above front window Greg26 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 8 09-07-2008 09:14 AM
front window leak cadmando Lights - Interior & Exterior 3 10-01-2007 05:44 PM
