Old 05-04-2016, 11:26 AM   #1
2018 25' Flying Cloud
St. Paul , Minnesota
Leak in black water flange
We are on the road in first trip with our upgrade to 19' FC. I noticed a drip in the flange that connects the black water pipe to the underbelly. We're still under warranty but t far from airstream dealer. Looking for advice, seems I have several options:
  • Take it to SOB service center (would have to pay for repair)
  • Catch the drips and empty regularly until we get to airstream dealer
  • Try to caulk it myself
Any advice is welcome.
Emily
rothse99 is offline   Reply With Quote
Old 05-04-2016, 11:37 AM   #2
CRH
1995 25' Excella
xxxxx , xxxxxx
The leak is probably gonna be at the clamp joint behind the belly pan. Caulk won't fix it. I would just use a catch pan and let a dealer fix it.
CRH is offline   Reply With Quote
Old 05-04-2016, 01:03 PM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
Do not caulk until you know for sure where the water is coming from. It may be a leak above the belly pan and just exiting at that point.
The pan may need to be dropped to determine where the water is coming from.
2004 Excursion 4x4
Old 05-06-2016, 07:17 AM   #4
2018 23' Flying Cloud
Savoy , Texas
Does it appear that the drain hit the ground? Our 22fb is close to the ground also.
SpinWhite is offline   Reply With Quote
Old 05-06-2016, 11:55 AM   #5
Cajun Traveler
2014 27' FB International
Slaughter , Louisiana
Mine leaked but it was leaking from the rubber flange inside the underbelly. All they had to do was drop the underbelly and tighter the clamp holding the rubber flange to the holding tank. The airstream dealer did it while waited. Your problem seems minor.hope I'm correct.
Billyg is offline   Reply With Quote
Old 05-07-2016, 06:18 AM   #6
Thanks all for replies. I was able to determine its a fresh water leak. If I disconnect the city water input, the drips stop. Hopefully it will be an easy fix once I get to a dealer.
Emily
How is flange installed for Black water tank Tony S Plumbing - Systems & Fixtures 4 05-15-2013 06:21 PM
Black water tank valve flange Safari64 Waste Systems, Tanks & Totes 1 09-22-2011 07:50 AM
Black Tank-To Flange or not to Flange? Mrwaterway Waste Systems, Tanks & Totes 4 12-02-2009 09:02 AM
Replacing 1963 Safari black water tank flange?? christianMT Waste Systems, Tanks & Totes 0 05-30-2008 07:51 AM
Black Water inlet flange Dave Shanahan Waste Systems, Tanks & Totes 1 08-18-2002 03:09 PM
