Old 06-30-2016, 07:56 AM   #1
Leak in Bathroom
Hi, I have a 2010 23D international serenity, which I love.
This year when I started camping I found a small link by the
toilet value. when I have the water on from the pump
no leak, when I used the water from the city water line
it leaks. I have used varies place to try and see if it is the pressure
of one particular place. no good. seems anytime i use the city
inout to the airstream it leaks. do I need a new
input value. Not sure . any help would be appreciate.
My home water never caused a leak now it does.
Thank you!
Blauth is offline   Reply With Quote
Old 06-30-2016, 08:15 AM   #2
Granbury , Texas
Your PEX fitting is the problem. You will need to cut the line and install a new fitting. There is no known way to tighten the factory fittings and once they start leaking it's replace time. The reason the city water causes it is the higher constant pressure than the pump. Check and be sure your built in pressure regulator hasn't gone out and is allowing too much pressure inside the trailer. Try hooking up a pressure regulator on your water hose outside and see if that stops the leak. They use to give you one of those hose regulators when you bought a new trailer. I still use one if pressure is high from campground so my hose won't get stretched in the sun and burst. I also have a pressure meter on my hose so I can monitor the pressure at the campground fawcet coming into my trailer.
cabinetmaker is offline   Reply With Quote
68 ambassador bathroom starting point - bathroom renovation hedgerocks Plumbing - Systems & Fixtures 1 03-18-2015 03:55 PM
Bathroom vanity and Bathroom vent lights... sovereignrwe Electrical - Systems, Generators, Batteries & Solar 10 01-05-2010 06:30 AM
Leak in 94 Excella bathroom ernesto ca Sinks, Showers & Toilets 1 08-11-2008 03:45 PM
