Old 04-19-2014, 03:04 PM   #1
GAStreamin's Avatar
2012 25' Flying Cloud
Moultrie , Georgia
Leak from AC
We have had a big rain exactly a week after getting our new AS and we have a leak coming from air conditioner. It was not parked level. Would tightening bolts and resealing do it? Am I missing something else I might should do?
GAStreamin is offline   Reply With Quote
Old 04-19-2014, 03:41 PM   #2
1977 Argosy 24
Milltown , Wisconsin
Tightening the bolts might fix it. Otherwise you have to lift the air conditioner to replace the gasket between it and the roof.
ventport is offline   Reply With Quote
Old 04-19-2014, 04:01 PM   #3
SteveH's Avatar
Common Sense , Texas
Not saying this is your problem, but I had a leak when it rained hard because there was a crack in the air conditioner drain pan. Just saying it's not always the gasket.
Regards,
Steve
Old 04-19-2014, 04:19 PM   #4
GAStreamin's Avatar
Moultrie , Georgia
Ok so while I'm up there I will check gasket drainpan?
Leak then no leak. gandttimes Leaks - Weatherstrips, Gaskets, Caulks & Sealants 0 10-04-2013 01:34 PM
Leak: Fired Up Hot Water, Now There's A Leak SSChanger Fresh Water Systems 4 07-15-2009 08:46 PM
Water leak James Schmidt 1993 Excella 1000 11 02-02-2004 07:54 AM
possible plumbing leak or water leak jamesl Repairing/Replacing Floor &/or Frame 1 04-06-2003 10:52 AM
Rainwater leak James Schmidt Leaks - Weatherstrips, Gaskets, Caulks & Sealants 8 09-11-2002 06:28 AM
