Old 05-08-2014, 11:12 AM   #1
Beer Snob's Avatar
2006 25' Safari
1966 26' Overlander
Wainscott , The Hamptons, Long Island
leak at water pump
OK…not being so good at this stuff I made what looked easy complicated. When I de-winterized and watered up the system in my 2006 Safari I noticed a small leak where water hose enters pump (Remco 55). there was a drip where the hose meets a plastic piece that extends out of the pump. The hose was attached with a factory crimp clamp. In attempting to get the clamp off I managed to snap the plastic piece in half…half still in the pump. The plastic looks and feels like it might screw or snap out of the pump screw out and can easily be replaced. Can it? will it? How?
Thanks in advance if you are familiar with this and can give me some advice.
Beer Snob is offline   Reply With Quote
Old 05-08-2014, 11:20 AM   #2
Wise Elder
Jammer's Avatar
2010 30' Classic
A photo would help.
Typically there's a plastic or metal fitting that screws onto the threads on the black piece that comes out from the pump. That's probably what broke. Unscrew it, replace it with new, done. Typically you can get the hose assembly with the ends already crimped in place in the sink and faucet section of a building supply place.
Old 05-08-2014, 12:18 PM   #3
Beer Snob's Avatar
2006 25' Safari
1966 26' Overlander
here you go…..snapped "port." How do I get this thing out of the pump?? I could sit here and twist it counter-clockwise for the rest of my life!
Old 05-15-2014, 02:26 AM   #4
Beer Snob's Avatar
2006 25' Safari
1966 26' Overlander
Bump!
still in there.
Old 05-15-2014, 06:42 AM   #5
SteveH's Avatar
Common Sense , Texas
I believe the fitting screws into the pump, but not 100% sure. Can't see for sure in the picture. But even if it does, there may not be enough left of the fitting to get hold of it with a wrench. If not, you might try inserting a screw driver inside of it and see if you can get it out, or if you have an Easyout large enough, that might work. Good luck.
Regards,
Steve
Old 05-15-2014, 06:44 AM   #6
Landrum's Avatar
2014 25' FB International
Little Rock , Arkansas
Sorry. I have no idea. Maybe the pump manufacturer has good customer service??
Landrum is offline   Reply With Quote
Old 05-15-2014, 10:27 AM   #7
Wise Elder
Jammer's Avatar
2010 30' Classic
Sorry, I missed your post earlier.
You have a Remco Aquajet pump which uses quick disconnect or "quad port" fittings. Replacement fittings are available from many sources including amazon.com. Installation instructions for your pump are here: http://www.freshwatersystems.com/pro...manual2012.pdf
I believe that there is a slide release near the fitting. You would slide it toward the rear of the pump and then turn and pull on the fitting until it comes off.
The Remco part number for the fitting and hose assembly is 25-174. Available here, though the photo shows a worm drive clamp rather than a crimp: http://www.rvupgradestore.com/Aquaje...r-p/25-174.htm
Old 05-17-2014, 09:04 PM   #8
Beer Snob's Avatar
2006 25' Safari
1966 26' Overlander
Thanks, I'll take another shot at it tomorrow.
Pump doesn't turn off and it doesn't pump water either. I don't know what to do! Melimelo Fresh Water Systems 9 10-02-2013 10:55 PM
Water Pump Sprung Leak...Need advice FAST stonyfork Plumbing - Systems & Fixtures 10 06-14-2010 12:20 PM
Sunday morning Surflo 2088 pump water leak AirHeadsRus Fresh Water Systems 2 08-02-2009 01:20 PM
air pump vs water pump kamo Water Heaters, Filters & Pumps 22 02-27-2008 02:01 PM
68 water pump-should the pump cycle? Boondocker Water Heaters, Filters & Pumps 8 08-06-2006 10:11 AM
