Old 09-13-2014, 07:15 PM   #1
2001 27' Safari
New York , New York
Leak at ac unit
Any suggestions for tackling a leak at the AC? I have a 2001 Safari with a Dometic AC unit. Water is collecting in the "tray" covering the AC unit inside and also traveling above the headliner and dripping on the counter. It only happens in heavy driving rain. I've been up on the roof to take a look. Sealant around the unit seems to be in good condition. Can water be getting in the side vents of the AC unit?
archlab250 is offline   Reply With Quote
Old 09-13-2014, 07:22 PM   #2
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
I am thinking "clogged"'or otherwise restricted drain line ... If the trailer is not level, water may be finding another way out.
Peace and Blessings..
Channing
WBCCI# 30676
Old 09-13-2014, 07:24 PM   #3
2001 27' Safari
New York , New York
Trailer is definitely not level. Where do I find the drain line?
Old 09-16-2014, 09:53 PM   #4
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Sorry, did not see the post...
Well, the drain line should be coming out on the street side..underneath... just inside the curved lower panel.
Channing
WBCCI# 30676
Old 09-17-2014, 07:51 AM   #5
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
The clogged drain line mentioned above is the usual suspect, and the first thing to troubleshoot. That plastic tray that the AC sits in is designed to catch the condensate that drips out of the AC unit, and channel it into the drain line, which runs between the inner and outer skins, and usually is visible as a small diameter plastic hose sticking through the belly skin in the vicinity of the wheel wells.
Water can also get into this tray in a heavy rain. The tray should have drain holes drilled all around its perimeter. These holes are there to let rain water out, but don't extend into the channels that catch the condensate. Since you are having your leakage during heavy rains, it could be that these holes are either clogged with schmutz, or have been sealed by an overly ambitious caulker--something to check on your next visit top-side.
good luck!
Pensacola Unit vs. Big Bend Tallahasse Unit gypsymoth WBCCI Forum 23 04-07-2013 11:19 AM
Roof Leak, from the AC unit??????? Jim in Pima Leaks - Weatherstrips, Gaskets, Caulks & Sealants 6 08-16-2010 08:29 PM
Leak: Fired Up Hot Water, Now There's A Leak SSChanger Fresh Water Systems 4 07-15-2009 08:46 PM
shopping for a unit to join at unit rallies GoNomad WBCCI Rallies & Events 35 11-30-2006 03:01 PM
possible plumbing leak or water leak jamesl Repairing/Replacing Floor &/or Frame 1 04-06-2003 10:52 AM
