Old 03-23-2015, 09:54 PM   #1
mrrealtor's Avatar
1972 31' Sovereign
Racine , Wisconsin
Keep hitting my head!
I have hit my head hard 3 time now getting into my trailer on the top of the door on the "sharp" aluminum door jam.
Is there a good solution for this other than to remember to duck?
1972 Airstream International Land Yacht Sovereign
mrrealtor is offline   Reply With Quote
Old 03-23-2015, 10:03 PM   #2
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
On the way in or out? Inside, mine there is a foam/rubber bumper cushion which works well headed out. I would think it matches the arch on older trailers but can't vouch for it as mine is a 2003 model. Coming in is a duck for me at 6'4"
SeeMore is offline   Reply With Quote
Old 03-23-2015, 10:16 PM   #3
mrrealtor's Avatar
1972 31' Sovereign
Racine , Wisconsin
I hit going in. I have seen the pads on the new campers but can't find any site that sells them. But I hit on the very top of the door frame, not the wall inside. I'm only 5'9" and just started working on the trailer and doesn't feel to well and would like to avoid. I'm going to look for some kind of weather stripping to slightly cover it to take the "edge" off.
Old 03-23-2015, 10:26 PM   #4
2007 22' International CCD
If you are leaving the door open and going in and out while working on it, try a split piece of foam pipe insulation snapped over the edge.
That might help. Or a hard hat?😄
Since I'm an ex-Navy guy, the knee-knocker "hunch" going in that door is what I use...head and shoulders bent, knees lifted a bit more than usual to get clearance. I have whacked the interior pad a couple times before the "hunch" habit returned.
KE4GNK/AE
rmkrum is online now   Reply With Quote
Old 03-23-2015, 10:33 PM   #5
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
If you are "just working on it" at your domicile then a temporary solution like a foam strip or a hard hat works great. Closing the door for travel is another issue altogether. I have achieved an instinctual duck after years of use, but maybe the padded or hard vinyl/rubber seal strips found in car door jams might be worth looking into.
Old 03-24-2015, 07:38 AM   #6
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Hang something flexible down from the door frame to remind you to duck. It would only hang down a couple of inches.
My thought would be a short piece of 1/2" PVC pipe hanging horizontally from a couple of short pieces of light chain. If it is temporary, no decoration is needed.
I hang bungie cords from the windows when open to keep me from banging into the sharp lock plate on the window frame.
I find I hit my head more if I wear a hat or ball cap.
Old 03-24-2015, 09:18 AM   #7
Nomad518's Avatar
2001 25' Safari
Vancouver , Washington
If your wife is shorter than you, pull up a lawn chair outside your AS and see if you can get her to go in and out to make the repairs.
Nomad518 is offline   Reply With Quote
Old 03-24-2015, 10:36 AM   #8
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
I wear a hat most of the time to soften the blow. Have not learned in 10 years. Also bang the overhead cabinet door handles.
Old 03-24-2015, 11:31 AM   #9
The Sign Lady
1969 23' Safari
1974 Argosy 22
1964 24' Tradewind
Victoria , British Columbia
Same idea but only slightly more attractive. Hang a rubber duckie there....Get is duck...he he he .... Doh...I'm going back to work now that I've had my self entertainment for the day...
thesignlady is offline   Reply With Quote
Old 03-24-2015, 11:31 AM   #10
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
I still have the scars from knocking my noggin above the door on my Bambi II. Managed to peel some skin off just about every trip. My new Safari has larger door opening and a foam pad above the door. So far I have not hit it once.
MICHAEL
Old 03-24-2015, 11:49 AM   #11
Dallas Center , Iowa
Your head
First of all this must be George Bush's fault. Second, get an Airstream hard hat and keep it polished. Or, you will eventually learn the " duck your head" routine in time. Have you been tall very long?
All in fun......keep your humor it will help the healing process and put the stairway in the stored position and that will help. ������
Earthcreeper is offline   Reply With Quote
Old 03-24-2015, 11:51 AM   #12
Blacksburg , Virginia
head banging
I have hit my head on the Zip-Dee awning arm more times than I care to admit. I now put a flourescent micro fiber towel on the arm and it helps. Not directly relevant to your problem, but a strip of bright tape might help.
Buzzr is offline   Reply With Quote
Old 03-24-2015, 05:23 PM   #13
1978 Argosy 24
MooreHaven , Florida
Split pool noodles work great for that sort of thing.I put them on awning bars and the edge of the front window when its open and they come in bright colors and are cheap!
This is only temporary unless it works! Red Green
oldiesel is offline   Reply With Quote
Old 03-24-2015, 05:52 PM   #14
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
And.... it ..... is.... aluminum!!!
Peace and Blessings..
Channing
WBCCI# 30676
Hitting the road check list smallfry On The Road... 8 12-12-2016 12:52 PM
Twink hitting 8000 posts? CanoeStream Off Topic Forum 66 05-06-2007 07:25 PM
Hitting the Road! lewster On The Road... 27 06-22-2006 08:30 PM
Start on interior & hitting the road PodPeople All Argosy Trailers 7 01-04-2005 09:32 PM
THUD! Sound of head hitting monitor... Janet H Our Community 9 10-23-2004 11:18 AM
