Old 07-16-2018, 12:56 PM   #1
1979 23' Safari
Orlando , Florida
JwBlackburn
79 Safari International
Need to buy a new air conditioning unit. Recommended units re: Coleman? Domestic? Size BTU?
Thanks!!!!
JWBLACKBURN is offline   Reply With Quote
Old 07-16-2018, 06:25 PM   #2
TheGreatleys's Avatar
1974 27' Overlander
Baltimore , Maryland
Where are you planning on spending your summers?
I have a Coleman Mach 8 cub. I like Coleman because it has a condensate pump instead of gravity fed drip cups like the Dometic penguin.
Penguins are popular. That's what the factory uses these days.
The 9200 BTU Coleman Mach 8 cub is quite small, so it runs just fine on a 15A outlet. But then, most people prefer higher BTU units for higher temp camping. I try to stay out of places that go too far over 100 deg F.
Your ideal BTU choice will depend on where you're camping. Usual advice I hear is that bigger is always better. I don't agree. I think an AC unit is more likely to freeze up if it's oversized, and a smaller unit will be more power efficient. Best to match the unit to your needs as closely as possible.
TheGreatleys is offline   Reply With Quote
Old 07-17-2018, 10:30 AM   #3
rugjenkins's Avatar
1975 Argosy 28
Springville , Alabama
I have a 28 ft argosy and went with an air command 15k heat pump. For a 23ft in Orlando I would consider a 13k unit. I am not a fan of dometic. Who now owns Atwood. (Their customer service is horrible) If I had to buy another I'd get the Coleman .
Matt
rugjenkins is offline   Reply With Quote
