Old 04-16-2013, 04:36 PM   #1
1965 28' Ambassador
Bloomington , Illinois
Just starting! :)
Airstream 1965 Ambassador just got to it's new home! Ready to start working on it
janetuck is offline   Reply With Quote
Old 04-16-2013, 04:39 PM   #2
1965 28' Ambassador
Interior
This is a before picture....have to take out the stuff in the front end as the floor is bad in front of the door and under the front window where the water tank was.
Old 04-16-2013, 04:43 PM   #3
1965 28' Ambassador
After removing stuff in front of trailer
This is when I was working on taking out the couch, water tank and little tables on each side of couch. Also took out the fold up table and cabinet thing under the outside window.
Old 04-16-2013, 04:45 PM   #4
1965 28' Ambassador
This is after it's all out in the front.
Old 04-16-2013, 04:48 PM   #5
1965 28' Ambassador
Now to start the bathroom! Ick!!!
Not a lot of visible screws to remove. How is this attached. I need to be careful because we want to reuse it...
Any advice would be appreciated
Old 04-16-2013, 06:42 PM   #6
lonewolf1977's Avatar
1957 26' Overlander
Winston Salem , North Carolina
Congrats!!!
Airstreamin' dreamin'.
Follow our blog! http://theoverlanderproject.blogspot.com/
lonewolf1977 is offline   Reply With Quote
Old 04-17-2013, 06:34 PM   #7
1964 22' Safari
1962 28' Ambassador
enosburg , Vermont
You're tub/sink looks like my '64 safari. If so its a major PAIN....remove and reinstall the worst part of the whole can of worms!!!! The sink top was riveted to the fiberglass tub surround from the back. I had to drill out the rivets that held the entire unit to the hull. Remove drains, lines and vents. Slid the unit forward then disassemble the individual components. You're in for a real treat when you try to get your hands up through the back to do the water lines. Looks like you maybe caught one break. Was the fiberglass deck cut to install a free standing toilet? If so that should help a bit. Once you've delt with this part everything else is easy!
putback is offline   Reply With Quote
Old 04-18-2013, 07:04 PM   #8
1965 28' Ambassador
Thanks for the warning! I'll start on the rivets. And yes, I think it was cut for the toilet. It looks like home made plywood sides with carpet along the sides of the stool. Icky Thanks for the reply...I'll see how it goes...
