Old 10-10-2013, 09:49 AM   #15
RM66caravel's Avatar
1966 17' Caravel
Newport , North Carolina
Dexter still and there are many distributes check with local trailer (boat or utility) dealers.
Cliff
Gotta get busy! Have a great day! Now where did I put those revits?
RM66caravel is offline   Reply With Quote
Old 10-13-2013, 05:58 PM   #16
1964 22' Safari
1962 28' Ambassador
enosburg , Vermont
'62 should have a torsion axle. I have heard rumors that some early '62s had springs. Either way get rid of it. An old "set" torsion X will destroy your hard work. Spindles on pre '62 Xs have a history of failing and tearing up the wheel well area. $700 for a new complete exact fit X and never give it another thought. Gonna be a pretty little thing.....
putback is offline   Reply With Quote
Old 10-13-2013, 06:19 PM   #17
reinergirl's Avatar
Hollis , New Hampshire
Replace the axles, it's a upgrade that's worth it. At the very least, call Colin Hyde and get a quote. He's very competitive price wise and is a phone call away if you need help. Sometimes the early 60’s trailers aren't a direct bolt on and things need modification to fit correctly. His axles come assembled with brakes already on. He also will talk you though the process to help you choose the correct ratings.
As an extra bonus I've heard on The Vap ( The Vintage Airstream Podcast | Vintage Trailer Restoration ) that he intends to sell kits for a DIY aluminum interior endcaps, that might be something you are interested in.
His website is here;http:// colinhydetrailerrestorations.com
If you follow the link to my blog below you can see pictures of him doing the axles on my trailer last winter.
reinergirl is offline   Reply With Quote
Old 10-14-2013, 05:32 AM   #18
1962 22' Safari
denton , North Carolina
I did get a quote on the axle from colin, the total with shipping is going to be 815.00 I believe you should build your house on a good foundation, I think spending the money on a good axle will give me peace of mind down the road, literally. I am going to ask about the end cap kit, it would be awesome to get. I guess if I sat down and started to measure it, I could figure it out. I own a water jet and could cut the pieces with no scratching etc..
dcroadsters is offline   Reply With Quote
Old 10-18-2013, 07:38 PM   #19
1962 22' Safari
Ok, so I tried using the citri strip for cleaning the paint/zolotone off, I guess im too impatient. I am gonna order 10 pcs of 2024 144x48 and reskin the whole inside. my only thought is should I just skin over the old skin? sounds bad but really not a huge weight difference, its going to add 175 lbs if I used all 10 sheets not subtracting the cutouts. anybody have any thoughts about that?
Old 10-18-2013, 07:57 PM   #20
Colin H's Avatar
1957 30' Sovereign of the Road
1959 28' Ambassador
1949 24' Limited
Peru , New York
You should take all of the original skin panels out in order to remove all the mouse infested insulation, upgrade the AC & DC electrical systems & seam seal & install modern insulation. Although the weight addition may not be very significant, leaving all that funk in the walls is not the best way to restore an Airstream.
Colin
Colin H is offline   Reply With Quote
Old 10-18-2013, 08:01 PM   #21
1962 22' Safari
Colin, what type of insulation do you recommend replacing the original with? I do agree with you on replacing, the more I think about it the more I don't want to cover the or any problem.
Old 10-18-2013, 09:13 PM   #22
Colin H's Avatar
1959 28' Ambassador
1949 24' Limited
Peru , New York
This is like asking Forum members what the best tow vehicle is I have used Reflectex, Prodex, Fiber Glass, Rigid foam & combinations of these. You can probably do a search for threads on these products & form your own opinion...................or listen to the VAP for my opinion.
Colin
Old 10-20-2013, 07:22 AM   #23
KCN
KCN's Avatar
Jackson , Wyoming
I am doing a 62 Overlander -
I personally really struggled with stripping the interior skins - I used gallons of citristrip, pressure washer...they still look terrible and LOT of time (many days) and money wasted relative to the cost of just buying new aluminum, which I'm going to end up doing now anyway. So props to you for that decision.
I would echo Colin's advice to pull them out, though. In my case, I discovered broken ribs, missing stringers, sheared rivets, obvious leaks, etc.. My insulation was actually rodent free, but definitely had retained 50 years of dust and smoking and cooking odors. Plus, the structural concerns would have been more difficult to identify and correct if I hadn't pulled it all out.
You've already entered the black hole...too late to turn back now
KCN is offline   Reply With Quote
Old 10-22-2013, 07:32 AM   #24
1962 22' Safari
Ok I have another question, What is the general consensus on the material type of the interior skin, enough material to reskin in 2024 is 1200.00 or I can use 3003 for 385.00 any thoughts?
Old 10-22-2013, 07:56 AM   #25
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
skin materials
You Guys better do some searching.....if your price aware. I just replaced all the interior skins on a 1956. I used .030 and 5052. The 5052 came with a clear plastic coat that protects the surface form marks during work. The 4x8 sheets were 30 dollars each. You can polish them too, if your so inclined.
Name:	progress skins left.JPG
ID:	198513   Click image for larger version
Name:	rivet panel and Zolatone.JPG
Old 10-22-2013, 09:03 AM   #26
1962 22' Safari
I am a bit concerned with the cost but I would like to know the the grade will be ok
Old 10-22-2013, 06:34 PM   #27
1964 22' Safari
1962 28' Ambassador
enosburg , Vermont
You're right to be concerned. Be certain you get the right grade. I screwed up bad once, ordered the wrong #. 4 ft X 12 ft for the ceiling. To soft, ripples everywhere. Used it on the curbside lower where it was mostly covered by cabinets & appliances. Reordered the proper hardness for the top. Smooth as glass. I've forgotten the #'s. Look through the skins and ribs section and get it right the first time. Look up post by Aerowood. He's the first one that comes to mind that really knows aluminum.
Old 06-11-2014, 08:01 AM   #28
1962 22' Safari
Update!!
progress has been made, a new axle from inland rv and new wheels and tires...
ID:	214035   Click image for larger version
ID:	214037   Click image for larger version
1962, 1962 safari
Video - Successful Axle Job on 1964 Safari JitneyBead Axles 10 05-21-2012 09:07 AM
Lucky 28 :: 1962 Air Stream Safari indy Airstream Registry Discussions 0 08-19-2011 08:32 AM
Safari :: 2006 Airstream Safari SE Mrs Silverback Airstream Registry Discussions 0 08-19-2011 08:31 AM
Picking up first Airstream tomorrow – 1962 Safari Safari007 Member Introductions 8 05-08-2011 02:34 PM
Want to get my 1964 Safari ready for travel Safari Bob 1964 Safari 3 02-24-2011 07:32 AM
