Old 09-28-2012, 02:07 PM   #1
Haoleman's Avatar
1972 Argosy 20
Lanesboro , Minnesota
Images: 20
Jacking question
As I am getting ready to paint my wheels on my Argosy 20, I am unsure where to put a jack and don't want to damage anything. Also, what type of jack is a safe bet to carry with on the road. Any help would be appreciated
Haoleman is offline   Reply With Quote
Old 09-28-2012, 03:07 PM   #2
SteveH's Avatar
Common Sense , Texas
I seriously doubt the spot is still marked on your trailer because of it's age, but they come from the factory with a spot marked on the frame behind the axles of where to place the jack.
But that aside, there is a plate where the axles are bolted to the frame, and the trailer can be safely jacked under that plate.
I use the jack from my truck, or drive one wheel up on a block to lift the other, but that won't work on your 20' because I believe it is a single axle. I must use a 4X4 block with the truck jack.
Old 09-28-2012, 07:01 PM   #3
nilesrob's Avatar
Marietta , Georgia
Images: 12
Foolproof.
The Slowsky's
2008 Airstream 27FB International Ocean Breeze
2014 Ford F250 King Ranch 4X4 w/6.7L Diesel, Hensley Hitch
WBCCI #1271
travelwiththeslowskys.com
nilesrob is offline   Reply With Quote
Old 09-28-2012, 07:08 PM   #4
1988 32' Excella
Robbinsville , New Jersey
Originally Posted by nilesrob View Post
Foolproof.
Not on the OPs single axle.
Old 09-28-2012, 07:15 PM   #5
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
Along with some wood blocks I carry a 6t hydraulic jack. I have 2 axles so could use the block method most times but for the time that won't work I have the jack. They'e available from many sources and not expensive. Good insurance. Mine was only around $25 or so. For a smaller trailer you don't need a 6t and then smaller ones are even cheaper.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 10-01-2012, 08:19 PM   #6
mefly2's Avatar
2015 25' FB Eddie Bauer
LOL ... us singles have to stick together ...
Old 10-01-2012, 08:40 PM   #7
nilesrob's Avatar
Marietta , Georgia
Images: 12
Oops! My bad.
The Slowsky's
WBCCI #1271
Old 10-01-2012, 08:49 PM   #8
2006 19' Safari SE
Hayes , Virginia
My 2006 Bambi 19' is marked on the curb side only, behind the tire on the bottom of the trailer. Although street side not marked, can I assume the left lifting spot is adjacent to, or directly across, from the right side spot? Sorry to butt in.
mocus is offline   Reply With Quote
