Old 11-27-2010, 09:24 PM   #1
2010 23' FB Flying Cloud
Smithville , Texas
Jacking
My 2010 23 FB Flying Cloud manual recommends jacking at the designated spot, marked by a decal pointing to a plate where the jack should lift, right in front of the rear stabilizing pad.
This works fine when the trailer is not attached to the TV but not worth a hoot when attached; it just puts the weight on the TV and it hunkers down making my jack unable to lift the axles clear.
What is wrong with jacking on the frame between the tires?
Matt & Virginia Kline
2010 FC23FB
2016 F-350 6.7 Diesel (Overkill and loving it)
Matt Kline is offline   Reply With Quote
Old 11-27-2010, 09:32 PM   #2
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, nothing wrong with that; Actually some of us prefer to use a bottle jack on the axle mounting plates. The other way is fine if you have the tongue jack holding the front up.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
ROBERTSUNRUS is online now   Reply With Quote
Old 11-27-2010, 10:08 PM   #3
tpi
Trabuco Canyon , California
I jack under the mounting plates as in this pic (not my pic). I'm careful of the tanks located very closely nearby.
tpi is offline   Reply With Quote
Old 11-28-2010, 07:33 AM   #4
Levon's Avatar
1985 27' Sovereign
1981 22' Excella II
Colbert , Georgia
Images: 168
Jacking/Changing a Flat
Greetings Matt,
While traveling with a tandem axle, I carry a 2 x 6 board about 14" in length. There is another 2 x6 board attached on the top of it that is stair stepped(shorter in length)...When a wheel needs to be removed and the spare used, I just place the stair step board behind/or in front of the good wheel/tire and pull up onto it...lifts approx. 4 ", but enough to add the spare. I think it is safer and faster changing a flat. My brother-in-law and I have changed several flats in approx. 15 min. and were back on the road. Just thought this might be something I would pass along.
When you have the time, visit my web site here:
Airstreams - Southern Antique
Best Regards,
Levon
Levon is offline   Reply With Quote
Old 11-28-2010, 07:47 AM   #5
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
It is not recommended by airstream. No other reason.
Michelle TAC MT-0
Sarah, Snowball
Jacking up lightng Jacks, Stabilizers, Lifting and Leveling 8 04-25-2010 07:36 AM
Jacking up a new Airstream.. SafariSS Axles 13 02-09-2007 06:03 PM
Jacking the Caravel Melody Ranch 1969-1971 Caravel 6 05-23-2006 05:50 AM
jacking up '72 Overlander TimM Jacks, Stabilizers, Lifting and Leveling 4 01-29-2006 04:25 PM
