05-22-2019, 03:57 PM
Santa Rosa
Jack one side with tongue jack extended?
I have a 2018 25’ Flying Cloud. I’d like to jack up one side so that I can remove both wheels in order to diagnose a non-working brake assembly. Trailer brakes are new to me, so I want remove both wheels to compare the two assemblies.. (It’s under warranty, but I’m guessing the repair will be simple and taking it to the dealer is inconvenient).
I know I need to raise the four supports, but should I jack it up with the tongue jack extended, or should I lower the trailer onto the hitch of my tow vehicle?
-Sean-
05-22-2019, 04:28 PM
2000 25' Safari
Davidson County
, NC Highlands County, FL
I've done it both ways. If on level ground I mostly jack up without the vehicle attached. If it is on unlevel ground I sometimes connect the tow vehicle. In either case, use chocks on the tires that remain on the ground.
Alan
05-22-2019, 04:44 PM
Santa Rosa
Thank you, Warn
05-22-2019, 04:52 PM
2000 25' Safari
Davidson County
Before jacking up, look at the wire connections behind the wheel. I've had the connectors come apart while traveling (road debris?) and all I had to do to restore brakes was reconnect the wires. You also can check voltage between the two wires going to the brakes at the connectors (with brakes activated) to see if there is enough voltage to activate the brake magnet.
Alan
05-22-2019, 04:58 PM
Santa Rosa
I’ll try and those suggestions first, thank you.
05-22-2019, 06:14 PM
2014 25' Flying Cloud
Cuddebackville
, New York
I always jack it while hitched to the tow vehicle. That way I'm sure it won't move.
2019 Ford Expedition Platinum
05-22-2019, 09:33 PM
Santa Rosa
Thats a good consideration, W&S, thank you.
05-23-2019, 09:56 AM
Married with Airstream
2004 25' International CCD
Vancouver Island
, British Columbia
Hitched to the tow vehicle means no worries - Safety First
La Dolce Vita Brick & Mona
We're Married With Airstream dot com
2004 International 25CCD Registered Name "Blue Streak"
2013 F-150HD FX4 SuperCrew Lariart (MaxTow) "Red Dragon"
05-23-2019, 10:02 AM
Newcastle
, Oklahoma
I've also done it both ways and either is fine. But, I always put a jack stand under the front by the tongue jack just in case of mechanical failure on the jacks part. You probably already do this but I also put jack stands under the trailer frame near the axles and I stack the two tires and slide them under the frame also. I am overkill when it comes to safety.
Good Luck
MC
05-23-2019, 10:49 AM
Our AS hitch jacks are not designed to take lateral movement and don’t have a wheel to compensate for it. Use the tow vehicle. If you have lateral movement a hitch jack could collapse, a tow vehicle will not.
On this topic, always chock your wheels before hitching or unhitching. Not long ago, I heard a big crunch as a neighbor was hitching up. Unknown to him, his wife had just removed the wheel chocks before he got in the truck to hitch up. He backed into the hitch and the hitch jack buckled as the trailer moved back. It was a recent model AS Classic 30. Everyone saw it and brought portable jacks over to get them on the road, but he was inconvenienced with not being able to unhitch until he located a new jack.
05-23-2019, 10:05 PM
Santa Rosa
Thank you Mickey and Jr, better to be safe.
05-24-2019, 09:03 AM
2013 25' Flying Cloud
Wheaton
To get access to the brake assembly, you will need to remove the brake drum.
Assuming you have Dexter Nev-R-Lube wheel bearings, the drum is held in place by a large spindle nut.
You will need the following tools; 1 7/16” socket (not a common size), external snap ring pliers, a hefty breaker bar to remove the spindle nut and a torque wrench (160 ft-lb minimum) to reinstall the nut. Don’t use torque wrench to remove the nut!
Greg
05-24-2019, 05:13 PM
Santa Rosa
Thanks Greg, I’ll be sure I have the tools before I begin.
05-25-2019, 07:42 AM
Jupiter
Think it through - the opposite side tire sidewalls taking the load, compression of the spindle(s) versus the track of the torsion arm, the lateral creep away from the jack point as the weight settles - its not a slam dunk hinged weight transfer, has a bunch of fluidity built in.. . . ..those forces have to be 'unwound' and released when lowering the lifted side.
I've rerailed 40-ton subway cars and we used hydraulic jacks and cribbing, stacking timber and boards to get hard points to control lifts etc. After the first time my trailer surprised me with a little toss of the jack bottle from lateral shifting I went to setting hard points on the opposite side, lift the far side enough to take some of the weight off the tires and make a solid hinge point using 6x6 and 4x4, 2x4 blocks then lift away on the repair side w/o wondering what will get potion of motion from thrusting so much weight laterally into the suspension and tires...
The days are short and the night is long and the stars go tumbling by.. . ~Airstream~
05-25-2019, 12:45 PM
2015 25' FB Flying Cloud
Sandy
, Utah
If the wires are intact connect to your TV and have someone step on the brake. Take a compass and hold it near each wheel. The brakes work by energizing a magnet and the magnet will attract the compass needle if it is working.
05-25-2019, 01:56 PM
Santa Rosa
Thanks wabbiteer, I don’t have large pieces of milled wood, but I could put my shortest set of jack stands under the opposite axles prior to the work.
-Sean-
05-25-2019, 02:03 PM
Master of Universe
2008 25' Safari FB SE
Grand Junction
I also had the brake wire connections behind a wheel come apart, so check that first.
I've jacked it up both ways. One time with the jack extended, I was working on it with a very experienced trailer mechanic and neither us gave it a second thought. But as I think about it now, I think it is safer and better for the jack if the trailer is hitched. Of course if the truck isn't braked and the transmission isn't in park, the whole thing can move. I prefer chocks under the opposite side no matter how you do it. If hitching is not an option, you could put the tongue on a lot of blocks instead of keeping the jack extended, but that seems the worst possible and unsafe option since blocks easily tip over if the trailer moves a little. And I also use a jack stand as a backup when I jack up a vehicle to work on it. One time I was working under the Airstream and the space over my head seemed to be getting lower and lower. I crawled out before I couldn't and noticed the jack stand and the jack were sinking into the ground—if the ground can be compressed, put boards under the jack and jack stand.
Gene
05-25-2019, 05:31 PM
Jupiter
Nothing is ever to touch the axles or torsion arms, only hook up points for wresting serious weight are the knife-edge steel axle mounting plates, the tubes used are hollow & just keep things flying in tight formation, only hugged by the machines they use to do alignments by adjusting the preset bend in them.. .
05-26-2019, 12:09 AM
Santa Rosa
Thanks for so many helpful tips. I’m going to drop the tongue onto the TV. I’ll start with Rocco’s compass tip, partly because it seems like a super simple diagnostic test, and partly because I have a really nice orienteering compass that I like to find excuses to use. If all 4 “attract” the compass when brakes are applied, I’ll then check the wire connections. If it comes to the point of having to remove the wheels, I’ll use opposite side jack stands (not on the axle tubes) with the stands on sturdy wood as suggested by Wabbiteer and Gene.
I hope to do this next week, I wanted to form a plan before starting...I’m glad I waited, you have all provided lots of useful ideas. I was unaware the axle tubes are poor support points, to be honest, that’s exactly where I would’ve placed the jack and jack stands.
I’ll add an update as soon as I have more info.
-Sean-
05-26-2019, 05:02 PM
Master of Universe
Grand Junction
The jacks should be under the frame and no where else. It runs from front to back on each side just behind the wheels. You can feel it through the belly pans. Centering a jack on the frame requires being sure of just where it is—a sturdy piece of thick plywood helps make sure you catch the frame completely. If you jack in the middle of a belly pan you will be very unhappy, possibly piercing one of the tanks.
Gene
