Old 06-15-2015, 12:37 PM   #15
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
I will assume the OP is looking for something like the fly on modern day camping tents. The fly provides an air space between the sky and tent. Providing shade as well as cutting down the condensation and heat in the tent.
TG Twinkie is online now   Reply With Quote
Old 06-15-2015, 01:09 PM   #16
greghoro's Avatar
2013 25' Flying Cloud
Wheaton , Illinois
Just thinking... You would want your solution to not trap the hot air being expelled by your AC unit on the roof.
Greg
greghoro is offline   Reply With Quote
Old 06-15-2015, 01:22 PM   #17
1996 25' Excella
Tillsonburg , Ontario
The material tsunami mentions is being used on sun facing windows on park model homes in Texas. It is basically a tight black weave that lets very little light through but still has enough open space to ventilate. It could work very nicely if the OP could rig a ridge pole along the top of the trailer. Tie off the eaves to trees and the wall mount for the awning.
Anything attached to the awning would be problematic if you need to retract the awning for high winds or storms
JCW
JCWDCW is offline   Reply With Quote
Old 06-15-2015, 01:41 PM   #18
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
Why not just move? It might be easier, just keep it simple.
Old 06-15-2015, 01:53 PM   #19
basecamper's Avatar
2008 Base Camp
Elizabethtown , Kentucky
We have an Airstream Basecamp. In the heat of summer, when we are parked in the sun, we strategically place three triangular shade sails (Amazon) to block the direct sunlight on the roof and sides....and it makes a huge difference. Shade sails are rain and wind permeable, so you don't have to worry about the wind getting under them/lifting them up, plus you still get breezes underneath. We attach them to the top of the Basecamp with bungees and to the ground with bungees and lightweight metal stakes. The shade sails even look "cool"....not at all like tarps.
basecamper is offline   Reply With Quote
Old 06-15-2015, 02:20 PM   #20
robwok's Avatar
1964 26' Overlander
Richmond , Virginia
Images: 35
Ditto on the shade sails. They're cheaper, lighter, and they should pack better.
Rob
robwok is offline   Reply With Quote
Old 06-15-2015, 07:31 PM   #21
FCloud9's Avatar
Mohnton , Pennsylvania
Base camper,
Would really like to view a photo of your sails setup w. your Airstream....sounds like an excellent idea!
FCloud9 is offline   Reply With Quote
Old 06-16-2015, 02:04 PM   #22
basecamper's Avatar
2008 Base Camp
I should have taken photos, but I didn't...so I'll try and describe exactly what we do with shade sails. A big part of the solar gain from sunlight hitting directly on the Basecamp is from the sides (not so much from the top). We attach one corner of each triangle to the top with bungees. (The Basecamp has some bars on top that we can attach to.) We then bring the remaining two corners of each triangle OUT and downward toward the ground and, using bungees and lightweight aluminum tent stakes, attach to the ground. So, the shade sail is actually at about a 45-degree angle in relation to the Basecamp. (You can walk underneath between the Basecamp and the shade sail.) We do this with all three shade sails, overlapping them in places and placing them where they will best follow the path of the sun as it moves across the sky. (We ordered our shade sails from Amazon. Prices were reasonable there. They are available in triangles or squares in various colors and sizes. Our blue triangles are very cool....both in appearance and function!)
Old 06-17-2015, 06:44 AM   #23
carver 1's Avatar
2011 30' Classic
2007 25' International CCD
1993 32' Excella
Largo , Florida
Images: 30
Phifertex.
Used on boats to provide shade and repel insects under the Bimini. Can be made to shape with a sewing machine.
>>ron<<
2015 GMC Denali 2500, 4x4, Duramax diesel, Topper, Pro Pride 3 P, Sendel 16" with Michelin LTs, one Yellow Labrador Retriever (AS security)
carver 1 is offline   Reply With Quote
Old 06-17-2015, 11:07 AM   #24
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Along the "sprinkler" thread, you could dig up some mister nozzles on some Flamingoes beaks..... Mount all over the AS!
Nah... May come home to "roost"...
Seriously, water misting reduces temp by evaporation, but water impurities will be an issue.
So, rather than put up a big tarp, what about rolling out some Reflectix on the roof? That would mean install/removal to tow the AS, but if you bungee from side to side it should hold in place unless you get a bad wind.
Peace and Blessings..
Channing
WBCCI# 30676
Old 07-22-2015, 12:59 PM   #25
54 Flying Cloud
KrisE MN's Avatar
1967 20' Globetrotter
1954 22' Flying Cloud
Grand Rapids , Minnesota
Love your idea! Can you tell me what size you got? There are quite a few configurations. There's 12 and 16'
I found this Video on how to attach sail shade to awning track rail.
KrisE MN is offline   Reply With Quote
Old 07-23-2015, 08:59 AM   #26
basecamper's Avatar
2008 Base Camp
We bought three different sizes of shade sails....16.5', 11.5', and 10' (Amazon.com : Outsunny Triangle Outdoor Patio Sun Shade Sail Canopy, 16.5-Feet, Blue : Patio, Lawn & Garden) ....and use them in different configurations, depending on the angle of the sun as it moves across the sky at a specific location. You would probably want to choose your sizes based on the size of your Airstream. Our AS Basecamp is small....only 16' long.
Old 07-24-2015, 06:59 AM   #27
Henderson , North Carolina
I have been considering NASA insulating paint on Insulating Paint | Insulating Ceramic Paint Additive | Official NASA Spinoff if this becomes a hugh problem when I am full timing. But the loss of the beautiful glow of the aluminum....... booo!
DearCatJ is offline   Reply With Quote
Old 07-24-2015, 07:38 AM   #28
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
DearCatJ- Research thread re: coatings here. You'll want an elastomeric paint.
http://www.airforums.com/forums/f478...lex-98479.html
SeeMore is offline   Reply With Quote
Over kill, or just over the top! airjeff Tow Vehicles 12 07-22-2010 09:13 PM
Al cloth spare tire cover wanted TomW Tires 7 01-19-2009 06:06 PM
Need to find a source for "wall cloth" PJM Upholstery, Blinds, Walls & Interior Finishes 6 07-01-2007 12:34 PM
cloth covered wire needed john hd Off Topic Forum 8 11-12-2006 08:40 PM
