Old 02-16-2008, 08:17 PM   #1
sob
1971 31' Sovereign
ZWOLLE , Louisiana
it's been parked since 1982
1971 sovereign 31'
here it is as it sits now in hot humid louisiana. it was parked here in 1982 give or take a year. now the tires are going flat and it just needs to be moved. I'm looking for suggestions to unearth this beaut. it is on a good sized slope and needs to hook to the back of my 86 k1500 4x4 (6000# shortbed w/350 and open 3.73 gears). Also the only way out is backing it straight out the way it went in which is up a hill about 200 ft. It's sitting on a penensula not wide enough to turn around.
I've been soaking everything with pb blaster as often as I'm out there in hopes the stabalizers and jack will wind up for the moment of truth otherwise they'll get the sawzall. almost forgot to mention there is just enough room for me to squeeze my truck in between the front of the trailer and the lake so theres not much room for error. I know I'll be digging out the back end a bit as the land has wash up around it and buried it slightly. Also those concrete steps look intimadating.
Sound like fun?
Thanks for your input.
Dave
ID:	54406   Click image for larger version
sob is offline   Reply With Quote
Old 02-16-2008, 08:24 PM   #2
Originally Posted by sob
1971 sovereign 31'
Sound like fun?
Dave
Sorry Dave.
Can't help you with the move, but I can tell you that the axles on that Airstream, are totally shot.
Old 02-16-2008, 08:34 PM   #3
Images: 59
Now would be a great time to invest in a front receiver for the 1/2 ton.
Old 02-16-2008, 09:11 PM   #4
jump's Avatar
2013 30' International
lubbock , Texas
what about a winch?
I don't suppose there is any place to attach a winch at the rear to pull it far enough back to turn around?
It does look as if the suspension has left the axles.
Good luck with it.
jump is offline   Reply With Quote
Old 02-16-2008, 09:14 PM   #5
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
How far does it need to be moved? Just a couple hundred feet, or are you taking it somewhere to work on it?
I moved a slightly smaller trailer that had been parked a similar amount of time, we wound up taking a chainsaw to several trees to give enough clearance. Can you drag the concrete steps out of the way? That would help give you more room. As far as the move, make sure the tires hold air, and inflate them as much as you dare (25+ year old tires probably won't last much longer than getting to the road), and try moving the trailer forward and back to make sure all the wheels turn. The one I got had a locked up wheel that had to be addressed before towing. Don't even hook up the brake wires until you get it out, and make sure everything still works. I would be very suprised if anything like lights, brakes, etc did.
If you are towing any distance (more than 5 miles or so), you should pull off the wheels and tires, remove the brake drums to make sure nothing is going to come apart while towing, and schlop some fresh wheel bearing grease into them before putting it back together.
If you are going to tow it more than a few miles, bring along bungee cords and screw gun/drill.
Take every tool you think you will need, then take some more. A small portable air compressor may be your best friend, along with several 2x6" boards, you may have to run the trailer on the boards to keep it from sinking into the dirt.
Make sure the tv antenna is secured, it looks like it is dangling, and could cause serious damage if it falls off while towing. It has also been suggested to open all the windows, then close them, to relieve stress on the glass after sitting in one spot for so long. The door opens back, so the wind will try to open it if not secured, if there is any doubt, tie it shut.
Old 02-16-2008, 09:47 PM   #6
NevadaGeo's Avatar
1978 31' Excella 500
Genoa , Nevada
I'd look at winching it backwards to a level spot. Or chain up all 4 wheels on your 1500 before trying to back it up and low range, if you got tire chains available. It won't want to leave that view easily for sure, and might want to go for a swim first. Get your buddy to tandem pull while you push. Extra insurance before you start is better than getting stuck and wishin.
NevadaGeo is offline   Reply With Quote
Old 02-16-2008, 10:02 PM   #7
samb's Avatar
1961 22' Safari
Union , Oregon
Images: 11
Dave--
Welcome to the insanity!
If you were closer, I would like to come to participate in the extrication.
I have snow drifts in my yard and it looks warm where you are.
My first thought was also a front receiver. It is much easier to watch and listen to the two or more reliable spotters that you will have strategically placed. Plus driving forward is easier on you and the vehicle.
It looks like a great find. Don't forget to take some photos as it comes out!
Sam
samb is online now   Reply With Quote
Old 02-16-2008, 10:06 PM   #8
sob
1971 31' Sovereign
ZWOLLE , Louisiana
Sorry Dave.
from the rust?
Old 02-16-2008, 10:10 PM   #9
Fyrzowt's Avatar
2000 25' Safari
West of Fort Worth , Texas
Images: 8
Great ideas so far. One other thing that is helpful when backing is a 2 way radio. Especially helpful in tight areas around trees, etc.
Good luck.
Fyrzowt is offline   Reply With Quote
Old 02-16-2008, 10:13 PM   #10
Fyrzowt's Avatar
2000 25' Safari
Images: 8
from the rust?
Dave, the rubber in the axles develop a "set" in them when they sit for a long time, or reach an old age. There is more info in the axle section if needed.
It's a common problem.
Dave
Old 02-16-2008, 10:57 PM   #11
sob
1971 31' Sovereign
ZWOLLE , Louisiana
Dave
I've been here on and off all day researching... I just haven't gotten that far yet but will look into this asap. Going to get a list together of what this outfit needs and either fix it, part with it, or part it out soon.
Old 02-16-2008, 11:11 PM   #12
1992 34' Limited
Falls Church , Virginia
Just my .02 cents....
sob -
IF the interior is all there, IF all looks good on the exterior, then there is NO GOOD reason to trash the unit - she can be made better than new..... with a few parts, time and $.....
If you choose not to be the one to save her, then give others here a shot.... bet you'll have more than a few willing to give her their best!
Pull that baby outta there, and see what she'll need....
Oh, and be sure to post LOTS MORE PHOTOS!!!!!! Great bunch so far!
Axel
SilverToy
SilverToy is offline   Reply With Quote
Old 02-16-2008, 11:12 PM   #13
sob
1971 31' Sovereign
ZWOLLE , Louisiana
Good luck with it.
winching it up the hill seems like a great idea compared to putting my truck between it and the lake but I don't know of anything to hook on to in the back and possible damaging the front if it drags. The bumper is not strong enough I don't beleive.
Looking into tractor services.
Old 02-16-2008, 11:26 PM   #14
sob
1971 31' Sovereign
ZWOLLE , Louisiana
Just going about 200-300 feet straight back uphill to level ground for renovations or for sale.
Any Airstreams parked in Berkley? empresley Off Topic Forum 8 03-22-2007 11:15 PM
whos permanently parked and living in A/S? nyairdream Full-Timing 18 07-04-2006 08:50 PM
72 Twinkie parked for good! goinnowhere Member Introductions 2 04-28-2006 08:26 AM
Parked our CCD and found this... Xray Our Community 25 07-20-2005 06:05 PM
Anbody have their A/S parked in Adairsville GA? 59toaster Our Community 0 02-20-2003 09:08 PM
