Old 02-16-2008, 11:53 PM   #15
sob
1971 31' Sovereign
ZWOLLE , Louisiana
Originally Posted by SilverToy
sob -
IF the interior is all there, IF all looks good on the exterior, then there is NO GOOD reason to trash the unit - she can be made better than new..... with a few parts, time and $.....
If you choose not to be the one to save her, then give others here a shot.... bet you'll have more than a few willing to give her their best!
Pull that baby outta there, and see what she'll need....
Oh, and be sure to post LOTS MORE PHOTOS!!!!!! Great bunch so far!
Axel
SilverToy
This trailer definately won't get trashed. It's almost sacred to me. I spent most every weekend for my entire youth camping and fishing there with my grandfather until he passed away. This airstream and I have a strong bond and to let it go for the wrong circumstances I feel would be an injustice to him and 'the camp'.
However with my growing family (our 2nd son is due in 2 weeks) and I may be taking a job which requires relocating once or twice a year we may need a larger full-time camper so any airstream profits would go towards that.
sob is offline   Reply With Quote
Old 02-17-2008, 06:39 AM   #16
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Originally Posted by sob
Just going about 200-300 feet straight back uphill to level ground for renovations or for sale.
In that case, you can forego most of what I told you. Make sure the tires are inflated, grab the previously mentioned 2x6's (they will spread the weight, and keep the tires from sinking into the sand). It would be a good idea to pull the trailer forward a few feet, and place the boards lengthwise under where the tires now are, then back over them. Once you get to the end of the first two boards, stop and pull them from between your truck and trailer, and place them behind the second set of boards. This also may keep the bumper and frame from digging into the ground as you back up.
It is not a good idea to hook anything to the bumper, as far as pulling forces, the bumper is only aluminum, and will tear fre of the 4 bolts holding it in place.
Old 02-17-2008, 07:09 AM   #17
2006 28' Classic
Lake Tomahawk , Wisconsin
Question?
Where in La. are you or the trailer. I'm sitting in Orange Beach with a Hummer! Am I close enough to help!
Bill
William Ales is offline   Reply With Quote
Old 02-17-2008, 07:44 PM   #18
1990 32' Excella
jonesboro , Arkansas
pulling out
before you attempt to back it out you need to realize that your transmission in reverse ony has 2 of the 6 clutches in the clutch pack engaged .You can very easily smoke your trans or take a lot of life of it backing up a steep slope even just 200 feet. You might get another truck to pull from behind or see if any one with a wrecker will put a 4 wheel tow dolly under the tongue and winch it out from the back. good luck
joel is offline   Reply With Quote
Old 02-17-2008, 10:16 PM   #19
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
Turn it around in place
Would it be possible if the steps and trees were cleared from the area to place some 2x6 boards under the area where the trailer currently is parked and turn it 180 degrees from where it sits now? The land area it sits on if sandy only needs the tires to be solid enough to keep them aired up for this operation and once turned it could be pulled easily up the hill. Use fix-a-flat to inflate them (so they will hold air better) then a compressor to air them fully. You could use a come along or chan fall to some tree trunks or ground anchors to accomplish the 180 turnabout and hopefully the tires would still be stout enough to allow this to happen. Otherwise jack the trailer up and makeup a homemade lazy susan to fit under the wheels and turn it around on that. You could use 3/4 inch plywood on top of fencing poles to make it up with (it doesn't have to be permanent or fancy!) American ingenuity will win out and you can turn it around in place and then pull it up the grade 200-300 feet. I bet if you brainstorm this issue you will come up with an idea that will work. Happy Trails, Ed
1967 Safari Twin "Landshark" w/International trim package
1999 GMC Sierra 1500 SLT
FORUMS MEMBER SINCE 12/16/2004AIR#7110
"My tire was thumping, I thought it was flat. When I looked at the tire, I noticed your CAT!" Burma Shave
BIGED52 is offline   Reply With Quote
Old 02-18-2008, 08:06 AM   #20
53flyingcloud's Avatar
1984 29' Sovereign
Savannah , Missouri
For 200 ft move down?, I would recommend for the move only~To use a bobcat, equipt with a rcvr to move it down with. No way would I attempt to move it with the 1500 (3.73) , the trailer hooked to the rear and, moving backwards..After you get it down..make the repairs ASAP..
Good Luck~! and, be careful~
53FC
53flyingcloud is offline   Reply With Quote
Any Airstreams parked in Berkley? empresley Off Topic Forum 8 03-22-2007 11:15 PM
whos permanently parked and living in A/S? nyairdream Full-Timing 18 07-04-2006 08:50 PM
72 Twinkie parked for good! goinnowhere Member Introductions 2 04-28-2006 08:26 AM
Parked our CCD and found this... Xray Our Community 25 07-20-2005 06:05 PM
Anbody have their A/S parked in Adairsville GA? 59toaster Our Community 0 02-20-2003 09:08 PM
