10-04-2011, 07:19 PM
1981 31' Excella II
Orlando
Is there anything that is less insulated than an Airstream?
I was out working in the trailer today and it seems that if the sun is out the AC is pretty much worthless. The ceiling is always hot. The heat from the sun goes through that aluminum skin and what little insulation is in there. It was about 80 today here in Alabama and sunny. I think that with the AC on it was still about 80. THe AC seems to be working ok. I got a 20 degree differential between the intake and exhaust. I am assuming hot ceilings are normal? I do need to clean the roof which will help it reflect more heat.
Perry
10-04-2011, 07:28 PM
Well Preserved
Colfax
, North Carolina
Perry, you can paint the roof sheet with white Kool-Seal, and it will cut down a lot on the heat. I did this on ours, and was able to comfortably work on the roof in the sun (in shorts), but our friends' identical Airstream with silver roof left me feeling like I needed to roll myself in some breading. I installed air conditioners on both trailers the same day.
Some days, it's just not worth chewing through the restraints.
10-04-2011, 07:43 PM
1976 31' Sovereign
Sioux Falls
, South Dakota
My air conditioner gets so cold in mine that I could hang meat in there.
10-04-2011, 08:41 PM
Corona
Perry
Add a small fan, for better circulation.
That should help with the temperature.
Also, don't wait for the trailer to get hot before you run the AC.
Turn the AC on early in the day, giving it a chance to cool things down, BEFORE they get hot.
10-04-2011, 09:46 PM
Indian Harbor Beach
We have two Fantastic Fans that we turn on first prior to setting the a/c. We also turn on the fan at the a/c control and let all the hot air out. We have practiced this many many times with great success even in upper 90 degree weather. We let all of this run for about 15-20 minutes, then turn the a/c on. Cools down pretty fast after that.
10-05-2011, 09:01 AM
2006 28' Safari SE
Worley
, Idaho
We discovered our AC unit had failed while returning home from Virginia via the southern tier. We were able to cool off the AS each evening enough to sleep comfortably by opening the windows, using the awning, and running the fantastic fan... at least until we got to Carlsbad, NM where it was 108 degrees. At that point we replaced the AC unit.
Idmtman
2006 Safari 28' SE (Sylvia) 75th Anniversary Edition
2010 Toyota Tundra 4x4
TAC: ID-1
10-30-2011, 08:37 PM
2001 34' Excella
Birmingham
, Alabama
I have had a '86 31footer and I now have a 2001 34' and both have very cold air. I suffer some heat at the beach when we are set up on sites without trees in Destin or Orange Beach, but the AC will freeze you at night.
Something is not right with your AC in my opinion. It is not hot enough here in Alabama in October for you to be uncomfortable in your AS with the AC on.
10-30-2011, 10:13 PM
Corona
AC quick check.
All RV AC systems can easilt and quickly be checked for proper cooling.
Run the AC for a few minutes and then measure the air temperature as it immediately exits the AC.
That temperature should be 18 to 20 degrees cooler than the ambient temperature inside the trailer.
If it's less than that, that would indicate a problem, such as low freon, or even a dirty coil.
10-31-2011, 04:37 AM
1981 31' Excella II
Orlando
I found a rats nest in mine and about half of the Evap coil was blocked with insulation. This helped a lot with increasing air volume. It was cold initially but now there is twice as much air. I get the 20 degree differential in temp from intake to outlet.
Perry
10-31-2011, 06:49 AM
Oswego
Perry
Something I found in mine...more sloppy workmanship. There was little effort to separate and sealing between the cold air outlet routing above the lower inside shroud and the warm intake air entering the bottom side of the shroud. In other words, I was recirculating a LOT of cold exiting air right back into the warm air intake before the cold air ever left the plenum. A little studying and duct tape and I had a significantly better performing A/C unit.
"All I want in this life of mine..... is some good clean fun" - Little Feat
10-31-2011, 06:58 AM
1981 31' Excella II
Orlando
Yes I have noticed at least on the Coleman's that it is possible to recirculate a lot of the air. This can also cause the thermostat to turn the AC off prematurely because it thinks that the temperature is lower than it really is. I moved the sensor outside the unit to fix this problem. Mine was set as cold as it would get and it was still cycling on and off until I moved the sensor. Right now, I have the cover off because of another issue with the fan motor not wanting to start.
Perry
10-31-2011, 07:07 AM
Oswego
Perry, I get the moving the thermostat thing, but not ensuring a good seal between intake and outlet air still reduces cold air exiting VOLUME considerably.
10-31-2011, 07:18 AM
1981 31' Excella II
Orlando
Yes you are correct and I will deal with that issue when I put the cover back on. Right now that is not a problem with the cover off. I do need something on the intake to keep from clogging my Evap coil again. I need to get on the roof to replace the fan motor. Someone has already put some dents up there messing with the AC so I don't want to cause problems. When I replace the fan motor, I will blow the Condenser and Evap coils out with compressed air. I may be putting more work into this 30 yr old unit that it is worth but it still works. I already replaced the outside shroud on it. Every possible opening on this thing was full of mud dobber nests. These things can ruin lots of stuff.
Perry
02-04-2012, 04:41 PM
1984 31' Sovereign
anycity
, New Hampshire
When we lived in ours for 2 years....we ran a soaker hose on the roof to cool the exterior surface. This allowed the A/C to catch up!
| Thread Tools |
| Display Modes |
