08-26-2007, 10:38 PM
#41
2004 28' Classic
1965 20' Globetrotter
Stephenville
Recollection
Originally Posted by flitzwhopper
Jimmy,
Wow! Nice job of keeping it from getting worse. Noticing that your are a Fire Chief leads me to believe that your driving behavior did not participate in the mishap. Probably, what you did while the disaster was unfolding kept things from getting much worse worse.
I'm interested in how you got to where you ended up. Specifically, was there any fish-tailing or did the trailer nose yaw hard right and then push you off the road or did the truck come around to the right in the tail like the rear end was steering.
The tire deflation alone shouldn't have had enough force to cause that magnitude of yaw. I'm guessing that the drop on the passenger side height interacted with the weight distribution bars in a positive feedback loop where the weight distribution tried to compensate for the un-level rear end by steering the trailer.
One thing from my experience. If your hitch assmbly is a bolt on, have a close look at all of the bolt on points. HIdden damage in that area is oftern overlooked.
Thanks for the compliment and comments Flitzwhopper, but from looking at our rig I somehow don't feel like I did a very good job.
Honestly, everything happened so fast I don't know that I can accurately answer your questions. I seem to recall (again not possitive) the truck cutting left first and I probably corrected in order to miss oncoming traffic. I do recall the trailer (very briefly) swaying violently behind us, then we jack-knifed and slid sideways off of the roadway.
Thanks for the tip on the possible hitch damage, I'll check that out.
Also in another post there was mention of the truck lugs possibly being loose. I was present when the young man from the tire shop removed the deflated tire from the truck and the lugs were tight.
We would also like to take this opportunity to thank everyone for their thoughts and comments, they are very much appreciated.
Jimmy and Marque (Zoey)
WBCCI#: 2344
Texas Highland Lakes Unit
08-27-2007, 06:16 AM
#42
Retired.
, At Large
I took a look at the valve stem pictured, and it is a snap-in truck valve stem. Good for 80 psi+. I prefer the bolt-together ones, they may leak, but they don't come blowing out of the hole.
08-27-2007, 06:26 AM
#43
1971 27' Overlander
Central
, Ohio
Boy I'm glad you said that Terry - I was beginning to think the metal bolt in valves we put in the new trailer wheels and tires was the wrong decision.
Jimarq, I am so sorry about your accident. But, you are alive and there are other Airstream's to be owned - jump back in the saddle.
08-27-2007, 08:01 AM
#44
1976 Argosy 24
Tempe
That's why they call it an accident
Jimmy,
I hope this freak event doesn't turn you off to trailering. You won't see many instances of your kind of accident and this would be the place to find them.
A real man or woman takes responsibility for the things that happen to them. The fact that you kept the rig out of oncomming traffic and ended up with the rubber side down is the best outcome that could have been expected once events started to unfold. You did a great job!
It is a moot point and not essential to anything at this point other than curiosity but I'm sticking by my theory of the unloading of the passenger side and causing the weight distributiion system to steer the trailer. The driver side tires on the trialer could tell some of the story.
Just for the record... I'm not bad-mouthing weight distribution devices. However, they are not designed to compensate for diagonal forces out of the horizongal plane which should not happen under normal circumstances.
Donna & Mike
Cowboy up! or go sit in the truck
Charter Member Four Corners Unit
WBCCI #2417
08-27-2007, 02:33 PM
#45
Sounds like you have a lot of advice about the Insurance Claim, repairs, total and things like that. I would like someone to tell you what caused the trailer to do that. You might want to Contact David Tidmore at Roger Williams in Weatherford and get his opinion on repairing the trailer and what may have caused the accident. Fischman
08-27-2007, 07:21 PM
#46
1977 27' Overlander
Trotwood
, Ohio
Overlander
When U say bolt in valve stems ,Do U mean like we used on the big trucks? I have seen them broken off but never blown out. I drove big rigs for 45 yrs never lost one. Once in a while U will get a leaker,but its rare.
Roger
08-27-2007, 07:30 PM
#47
Retired.
, At Large
Originally Posted by Mikethefixit
Overlander
Roger
The stems that are two piece, and clamp to the rim, don't blow out. They do occasionally, leak, like we have both said. The rubber ones, even the high pressure ones pictured above, do occasionally "leave the building". I have also broken off the bolt-together types, but have never seen one simply depart the hole.
08-29-2007, 09:44 AM
#48
Greeeneville
, Tennessee
Another View
I was traveling the Interstate when I observed a pickup truck overtaking me in the passing lane. I also observed his right rear tire was almost flat. I was running near 65 MPH and he was overtaking me. I am sure he had not realized the tire was so low of air. I hit my brakes hard and at the moment he was directly beside me, his tire blew out. His truck dipped right at first, then he corrected the steering and went left and into the center median, then crossed BOTH lanes and ended in the emergency lane on the right hand shoulder. This was a work truck loaded with tools etc in the back. Just a general observation here.
Kevin with Baity the Lab/Pointer //------AIR # 7303------\\ WBCCI 17109 visit my restoration blog at:
08-29-2007, 12:48 PM
#49
Tom, the Uber Disney Fan
2006 30' Safari
Orlando
I am so glad that there were no serious injuries.
Originally Posted by Jimarq
Will this accident have any bearings on our insurance premiums in the future?
Possibly, but not necessarily. The weekend we picked up our Airstream I hit a guard rail coming out of the first campground we stayed in and put a dent down the curb side. Three weeks after picking up our new Safari a deer ran into the front curb side corner of our Airstream. I took it to the factory in JC because I wanted it put back in new condition with hard rivets. Labor was the largest expense because the interior had to be removed from the front corner to the rear corner on that side. That also happens to be the side with the refrigerator, closet, bunk beds, and wardrobe. The total for the two repairs was a little over $9,700. My deductible was $500.
The week I after went to pick up the trailer in JC, I received a notice from the insurance company. When I saw the envelope I just knew it was either a bill for higher premium or cancellation. When I opened it I was SHOCKED to read that they were LOWERING my premium and would be issuing a refund check for $97!!!!! I couldn't believe it. Two accidents within the first three weeks and they were lowering my premiums!
It just goes to show that miracles do happen.
Family of Disney Fanatics
WBCCI# 4821
https://streaminacrossamerica.com/
08-29-2007, 02:12 PM
#50
1951 21' Flying Cloud
1960 24' Tradewind
West Coast
, BC
So, from this I get the impression that this is just like going to the carnival and throwing darts at balloons, the more you hit, the lower your rate goes.
Wow, I wish I had an insurance company like that .
Barry
Barry & Donna
Life is short - so is the door on a '51 Flying Cloud (ouch)
08-29-2007, 03:35 PM
#51
2006 25' Classic
Newport Beach
What a grim day for you. I have to know, how is Chester? Was he riding in your lap or do you have a harness or crate for him to use while you are on the road? Keep well, and I hope there is a fair resolution in your near future.
Cathy
08-30-2007, 02:11 PM
#52
2006 30' Safari
Orlando
Barry
I've been with Farm Bureau for every thing I own since shortly after I graduated from college. I bought my first policy from them in 1987.
WBCCI# 4821
09-07-2007, 10:57 PM
#53
1977 27' Overlander
Trotwood
, Ohio
Jim & Marque
Well Its been a few days.What did your insurance carrier have to say about your unfortunate turn of events? Was Curious who your Insurance carrier is. All the best to U. Later
Roger
09-20-2007, 09:40 AM
#54
1960 24' Tradewind
West Coast
, BC
Just wondered what the insurance company decided to do? I hope they have treated your fairly.
Barry
Barry & Donna
