Old 05-21-2015, 04:34 PM   #1
KatCave
Steamboat Springs , Colorado
Smile Is it possible to put a Lift Kit on a 16ft Sport?
We live in Colorado so like to camp in the backcountry on dirt roads. Is is possible to LIFT the camper with some type of kit or some other means? thanks! We have a 16ft 2010 Bambi Sport.
klogan1010 is offline   Reply With Quote
Old 05-21-2015, 04:53 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Welcome,
I looked it up for you,
http://www.airforums.com/forums/f437...it-102393.html
MICHAEL
Old 05-21-2015, 04:57 PM   #3
SteveH's Avatar
Common Sense , Texas
Since both Airstream and Casita use a Dexter axle, contact these people and see if this kit won't work: Casita (Dexter Torflex #10) Axle Lift Kit
Regards,
Steve
Old 05-21-2015, 06:34 PM   #4
AWCHIEF's Avatar
Images: 33
The source,
Dexter Axle - Trailer Axles and Running Gear Components - Torflex Lift Kit
MICHAEL
Old 05-21-2015, 07:27 PM   #5
Aftermarket supplier
widgetwizard's Avatar
Duncanville , Texas
"These people" are watching..
Do you have a Dexter #10 axle?
widgetwizard is offline   Reply With Quote
Old 05-21-2015, 08:05 PM   #6
2015 23' FB International
2007 19' International CCD
I raised my 19' Bambi with a Dexter lift kit. My suggestion would be to note the number on your axle then call Dexter and they will tell you which kit you need. The Axle number is on a sticker on the axle. It may be a No. 11 Torflex.
Stick with Dexter. The kits are well made and not too difficult to install. Will give you about 3" of body lift.
Steamy1 is offline   Reply With Quote
Old 05-22-2015, 12:16 PM   #7
KatCave
Thumbs up thanks!!
Wow! What a great response! This is the first time that I have posted and I truly appreciate everyone's knowledge and information. Great forum!!!
Old 05-22-2015, 12:26 PM   #8
2013 16' Sport
Boulder , Colorado
We took our Bambi to Boulder Offroad and they lifted it about 3 inches. Much better!
Seecue is offline   Reply With Quote
Old 05-23-2015, 07:34 AM   #9
2018 19' Flying Cloud
Eugene , Oregon
I find that when I scrape bottom on my Bambi Sport ( especially on driveways) it is the huge WD / Swaybar hitch (Husky Centerline) that is the culprit. Will a higher axle lift raise that as well?
tjwoods1 is offline   Reply With Quote
Old 05-23-2015, 09:09 AM   #10
AWCHIEF's Avatar
Images: 33
Raising the trailer should allow you to us a shorter drop bar and give you more clearance.
MICHAEL
Old 06-25-2015, 06:10 PM   #11
Eugene , Oregon
Drop Bar?
Sorry for my slowness - what do you mean by shorter drop bar - you mean the hitch height adjustment holes? If so- ours are the lowest - so we could move it up on?
Old 06-25-2015, 10:41 PM   #12
2013 16' Sport
Boulder , Colorado
Right. The intent is to level the Bambi as much as possible. If it is level now, and you lift the back, you would want to also lift the front to even it up again -- by raising up the ball attachment one or more holes. In our case, it was riding high in the front (exacerbating our clearance problem), so the lift kit on the Bambi made everything lovely and level.
Once you move the ball attachment up, you may have excess bar below it. If it poses a clearance problem then you can get a shorter drop bar (fewer holes). If not, just leave it.
Old 06-20-2016, 11:22 AM   #13
2014 16' Sport
Denver , Colorado
I also have a Bambi 16 Sport, live in Colorado, and need some more clearance. I snapped a picture of my axle sticker and believe that this is the Dexter 10 (I see a -10 number and a couple other 10s listed ). Can someone help me verify?
SkyDog is offline   Reply With Quote
Old 06-21-2016, 07:04 AM   #14
Duncanville , Texas
That is a #10 (3500lbs is the major clue)
Lift Kit on 22' Sport tallen5 2005 and newer - Bambi all models 88 05-22-2018 10:39 AM
Air 'Bags' - too lift or not to lift JourneytoRet Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 5 04-09-2013 10:09 AM
grand cherokee lift kit? shooter04 Tow Vehicles 1 06-24-2010 02:19 AM
3/4 ton suburban with 6" lift kit lohidoc Tow Vehicles 13 06-17-2007 06:07 PM
