Old 09-06-2015, 08:52 AM   #1
1965 26' Overlander
Ogunquit , Maine
Internal 110V wire placement
I was wondering if the factory 110V wiring was all run above the C-Channel withing the interior walls from outlet to outlet? I have a 1965 Overlander and want to know if any factory 110V wiring would be below the C-Channel within the belly pan. I had to drill out and replace two rivits on the front belly band and didn't want to drill into any wiring. Thanks, Dom
dominicjohn is offline   Reply With Quote
Old 09-16-2015, 10:53 AM   #2
johnnywood's Avatar
1978 31' Sovereign
1968 24' Tradewind
Salem , Oregon
As far as I know, the factory ran all 120v romex in the walls. It is likely that there are no wires under there unless a previous owner ran them under there.
johnnywood is offline   Reply With Quote
Old 09-16-2015, 02:20 PM   #3
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Yup.. only 'below' the floor was for the power inlet and to the outside electrical outlet beneath the dinette.
Peace and Blessings..
Channing
WBCCI# 30676
Best wire connector for 12 gauge stranded wire jcarnevale Lights - Interior & Exterior 6 04-14-2014 08:18 PM
Recommended 110V Wire Gauge SilverHoot Electrical - Systems, Generators, Batteries & Solar 13 02-28-2011 09:42 PM
Green wire/White wire magnets robbier49 Brakes & Brake Controllers 3 07-08-2009 06:26 PM
Two wire and three wire converters??? max7 Batteries, Univolts, Converters & Inverters 1 02-28-2008 05:27 PM
Wire ,wire, oh wire can it be ? 69 Silverback Electrical - Systems, Generators, Batteries & Solar 8 05-15-2003 11:09 AM
