Old 05-18-2015, 08:10 PM   #1
2016 30' Classic
Santa Rosa , California
Intermittent problem with both Fantastic vents
I recently purchased a 2015 Airstream with 2 Fantastic vents. I believe they are 3000 series (thermostat, rain sensor, 3 speed, auto/manual vent lift, ceiling operated). The problem I'm having is that intermittently, one or the other fan vents will not open (if closed) or close (if fully or partially open) when I actuate the auto open/close switch. During these times, the fan will also not spin at any speed setting (1-2-3) while the On/Off switch is toggled to On. This problem does not go away at any thermostat setting. I can manually open/close the vent although it is much harder to turn the knob than when the auto open/close switch is working properly. After a few minutes, up to several days, the open/close switch works again with no other changes made.
I thought perhaps the cause was the rain sensor picking up moisture, but if so, I believe it should close the vent automatically if it is open - however, this does not happen.
Am I'm missing something? Any ideas?
phann is offline   Reply With Quote
Changing roof vents to fan vents stgerdonly Roof Vents, Skylights & Fans 1 12-28-2014 05:42 PM
Intermittent brake loss problem solved 63air Brakes & Brake Controllers 2 07-27-2009 09:32 PM
Intermittent 12v elec problem & solution ole81 General Interior Topics 4 07-29-2007 10:01 AM
Fantastic Vents ? andyfuson Roof Vents, Skylights & Fans 11 08-31-2004 08:17 PM
Fantastic-Vents in 1973 Argosy Gunnyusmc All Argosy Trailers 2 08-19-2004 08:48 AM
