Old 08-02-2016, 03:45 PM   #1
PA BAMBI II's Avatar
1964 17' Bambi II
Strasburg , Pennsylvania
Interior rivet shear/tire pressure?
I found a sheared rivet head when I arrived at camp today. I am not new to Airstreams and have seen sheared rivet heads before and know the causes (unbalanced running gear, old worn out torsion axles, bumpy roads, combo of all three...)
I was surprised because I have a new axle, balanced wheels, light '64 Bambi and never a problem to this point.
I did add ten pounds of air to the tires before we left...46 lbs in Yokohama Supervan 356's. They were looking a little low and I was never sure how much pressure to run in them. Before fill up, both had around 37 lbs.
Could the added pressure on the tires have caused a rougher ride on this trip thus shearing the rivet?
PA BAMBI II is offline   Reply With Quote
Old 08-02-2016, 06:46 PM   #2
1979 23' Safari
Wayland , New York
"Could the added pressure on the tires have caused a rougher ride on this trip thus shearing the rivet?"
Could have, higher pressure means stiffer ride. Could just be coincidence. Give Yokohama a call and ask them for a load table for your tires so you can determine what the best pressure is for your trailer weight.
Old 08-04-2016, 08:35 AM   #3
1989 25' Excella
Greenbrier , Arkansas
Sure wish you had more replays to your thread,,, mine won't help you much,,
But,, hopefully by me jumping in here we will both learn something,, we have just put Michlin tires on the 89 Excella and the tire shop wanted to put 50lb in them,, I have fixed a few rivets in the tt but the folks we bought it from had visited EVERY state in the country, including Alaska. So it has been around,, the rivets don't bother me as much as the apparent flexing of the skin,,
Where I'm going is,, I feel 40lb or so should be good on these tires but who am I,, like you I feel too much air is hard on the tt,,, I first messaged Michlin and they told me 30 lb,, sounded a little lite so recon tacked by phone and the youngster on the other end said that since I had not been to a scale and verified exact weight( I told him the tt weighed 6500/7000) he would have to say put in max pressure of 50lb,,, obviously he wants to cover his end and is not concerned with the life of the tt,,
I sure hope this will get us both some info as like you I really want to be gentle on my friend,,
stkwhittler is offline   Reply With Quote
Old 08-05-2016, 03:18 AM   #4
1979 23' Safari
Wayland , New York
Page 22 has inflation tables for Michelin ms2 ltx as long as they're 16"+
http://www.michelintruck.com/assets/...k_Sept2011.pdf
Pages 19-20 might help on the yakahamas, with a little conversion,
http://global.yokohamatire.net/pdf/t...ast_Africa.pdf
Old 08-05-2016, 03:28 AM   #5
1979 23' Safari
Wayland , New York
Recall on ms2/ltx, not sure if this affects you or others
http://m.michelinman.com/US/en/help/...tude-tour.html
Old 08-05-2016, 07:43 AM   #6
Nowhere , Somewhere
Three year old recall. Any if those tires still in use would be reaching its lifespan.
1984 Avion 30p 9.1 meter. 2006 Dodge 3500 cummins srw short bed crew cab.
avionstream is offline   Reply With Quote
Old 08-05-2016, 02:07 PM   #7
2013 30' International
Anna Maria , Florida
I have the same Michelin LTX tires and I run them at 52 PSI on a AS that weighs travel ready about 7,400 lbs. I like to firm it up a bit and I still get a very nice ride. Everything in the trailer stays were we put it. Calculating your AS weight you should be ok with 41 to 43 lbs. I don't think however that it will soften you ride by much. Besides the pressure will build up over 50psi soon as you are on the road a while.
franklyfrank is offline   Reply With Quote
Old 08-05-2016, 02:15 PM   #8
1967 26' Overlander
Spartanburg , South Carolina
You can find a "CAT"scale at almost any truck stop and weigh your trailer. I use GoodYear Marathon tires and found on their web site a chart giving the pressures for a wide range of weights. Yokohama probably does too. Having said that, the aluminum "pop" rivets used inside can lose their heads just from heat expansion and contraction or flexing as you go down the road. I have probably replaced 20 or 30 rivets in mine over the years mostly along the rib where the front cap is fastened.
Jacob D is offline   Reply With Quote
Old 08-05-2016, 02:33 PM   #9
floridalarry's Avatar
1966 20' Globetrotter
Ormond Beach , Florida
I had purchased 225 75R 15 to replace 6 year old 225 75R 15 tires on my '66 Globe Trotter. The tire shop up-sold me to E Rated tires. I was running 80 lbs as required by the tire manufacturer. They said that would not be liable for blowouts or damage if I ran tires at a lower pressure. When I went to Lewisburg and spoke with the TMPS people, they told me that at 80 lbs I would be popping rivets. Sure enough I had 10 popped interior rivets. Re-riveted and bought 205 75R 15 Maxxis' at 60 lbs.
Larry & Linda Scovotto
WBAC #1021
Ormond Beach, FL
1966 20' Globe Trotter
2015 Nissan Frontier SL
floridalarry is offline   Reply With Quote
Old 08-05-2016, 05:50 PM   #10
1979 23' Safari
Wayland , New York
Was up pretty late last night looking into this. Best bet is call the mfg and ask. I also found some other interesting sources.
http://www.tiresafety.com/images/tir...t%20manual.pdf
http://static1.1.sqspcdn.com/static/...+inflation.pdf
Between the two you should be able to get a good idea with your tire specifics and load rating. There were some interesting notes in there with regasds to P tire pressure and increasing beyond a certain point doesn't add more load but affects handling and speed rating.
Old 08-05-2016, 11:35 PM   #11
"SPACE A"
2006 34' Classic
Fort Worth , Texas
Tire balance and pressure do have a bearing on the problem. Be as accurate as you can. Airstream recommends max sidewall pressure for what thats worth. I recently moved a bunch of weight aft installing Lew's solar lithium system, probably 200#s. On my return trip home I noticed a popped rivet on the outer skin near the upper rear entry door corner. The point is that the shell is moving all the time even when stationary due to expansion and contraction from heating and cooling. The aluminum colored stains you see around your trailer is dust caused by this friction just like dust from sanding with sand paper.
guskmg
Old 08-05-2016, 11:56 PM   #12
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, unless you had your tires and wheels spin balanced on your trailer, your running gear is not totally balanced. Trailer brake drums are not balanced. That is why I run Centramatics on my trailer.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 08-06-2016, 12:03 AM   #13
Arcticfox's Avatar
2013 28' Flying Cloud
Central , Saskatchewan
Wow. 40-50 lbs sure seems low from what I've read. Mind you with that being said, maybe what I've been reading has been out to lunch. I have been running mine at 60 cold and my 28' have a scale weight of 6500. The past couple trips I've had 3 rivet shear over about 10,000 miles.
Might be time to take a second look at pressures.
You folks that are running the 16" Mich in the 40-50 ranges, what are you seeing the pressure go to after running for a while? In my case my daytime pressure can go to 68-70 while running in the heat of the day according to my TMS
Thanks in advance for any input
Cheers
Doug
Trying to use my camera to create memories - not photographs!
WBCCI #2525 (Region-10 Unit #120)
Air #85270
Arcticfox is offline   Reply With Quote
Old 08-06-2016, 07:29 AM   #14
2016 25' Flying Cloud
Holly Springs , Mississippi
Doesn't CanAm Andy recommend running the Michelins at 44 psi? That's what I recall, and he's my go-to guy for all things Airstream-related.
2016 FC 25' FB-twin
2013 F-150 CrewCab 3.5 Ecoboost 4X4 3.55 Lariat
Bob662 is offline   Reply With Quote
Water Pressure: Shore pressure high, All pressure in trailer low.... bhooves Sinks, Showers & Toilets 9 10-16-2016 04:22 PM
Electric metal shear. copycat carl Ribs, Skins & Rivets 10 02-26-2014 09:08 PM
Hensley self tapping shear bolts adonh Hitches, Couplers & Balls 24 04-18-2012 12:01 AM
Tire Pressure Gauges- Pressure Varies! Ray Eklund Tires 14 07-06-2008 09:34 AM
Canadian Tire's $129 Tire Pressure Monitoring System SilverCottage Tires 9 10-30-2007 08:55 PM
