Old 08-07-2016, 01:50 AM   #15
1979 23' Safari
Wayland , New York
I think we're having a problem with the different versions of the ms2 tires. There are P, P extended load, and LT E rated versions. They have different max pressures. The Ps have 44psi max, the P XLs have 50 psi max, and the LT Es have 80 psi max. Think this explains a big chunk of the different pressures.
You've got to be sure you're comparing apples to apples. Little differences in aspect ratios can make difference as well.
This table shows how many different possible tires we could be comparing.
http://www.monro.com/datasheets/Michelin-LTX-M-S2.pdf
Old 08-07-2016, 02:38 AM   #16
Huh?
Ultradog's Avatar
1975 27' Overlander
Twin Cities , Minnesota
Images: 8
What are you towing it with?
A stiff suspensioned 1 ton will beat a trailer more than a softer suspensioned 1/2 ton will.
That's one thing those who recommend a gargantuan TV don't take into account.
Ultradog is offline   Reply With Quote
Old 08-08-2016, 05:56 AM   #17
PA BAMBI II's Avatar
1964 17' Bambi II
Strasburg , Pennsylvania
2012 Chrysler Town & Country minivan...600 lb. bars. We're not overdoing it.
Thanks for your insight, however. What you say is true.
"The difference between vintage and retro is that vintage is honestly old and cool. Retro tries to be but isn't."
PA BAMBI II is offline   Reply With Quote
Old 08-08-2016, 06:06 AM   #18
Nowhere , Somewhere
Correct WD bars help mitigate some of the effects of stiff suspensions. s. Lighter bars for heavier suspension. Good luck
1984 Avion 30p 9.1 meter. 2006 Dodge 3500 cummins srw short bed crew cab.
avionstream is offline   Reply With Quote
Old 08-08-2016, 08:11 AM   #19
2016 25' Flying Cloud
Holly Springs , Mississippi
Originally Posted by avionstream View Post
Correct WD bars help mitigate some of the effects of stiff suspensions. Lighter bars for heavier suspension.
But doesn't wheelbase also factor into bar selection? Andy at CanAm suggested 1,400 lb. bars for us -- towing FC25 with a crewcab F-150. He said stronger bars were needed to transfer enough weight to the front suspension, given the relatively long wheelbase.
2016 FC 25' FB twin
2013 F-150 Lariat CrewCab 3.5 EB 4X4 3.55 axle
Bob662 is offline   Reply With Quote
Water Pressure: Shore pressure high, All pressure in trailer low.... bhooves Sinks, Showers & Toilets 9 10-16-2016 03:22 PM
Electric metal shear. copycat carl Ribs, Skins & Rivets 10 02-26-2014 08:08 PM
Hensley self tapping shear bolts adonh Hitches, Couplers & Balls 24 04-17-2012 11:01 PM
Tire Pressure Gauges- Pressure Varies! Ray Eklund Tires 14 07-06-2008 08:34 AM
Canadian Tire's $129 Tire Pressure Monitoring System SilverCottage Tires 9 10-30-2007 07:55 PM
