Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > General Repair Forum
Old 05-06-2012, 06:31 PM   #1
lwp99's Avatar
Gold Canyon , Arizona
Interior partition corner joint failure - repair?
I have a 2005 25' Safari that has the corner joint (where two bathroom walls join) separating. There is a piece of Oak at the corner; then the 1/4" wall panels that should be fastened to the Oak. Has anyone else had this happen? If so, how did you make permanent repairs? I tried a brad nailer, but this was not successful. I have not yet attempted to take the entire wall apart - doing research before tackling that.
Thanks.
- Larry
lwp99 is offline   Reply With Quote
Old 05-06-2012, 07:08 PM   #2
reinergirl's Avatar
Hollis , New Hampshire
Can u post a picture?
reinergirl is offline   Reply With Quote
Old 05-06-2012, 11:03 PM   #3
lwp99's Avatar
link to picture
I tried attaching a picture to my response - not successful.
Try this link.
Thanks.
- Larry
Old 05-07-2012, 09:18 PM   #4
lwp99's Avatar
Another attempt at posting a picture of problem area
If the attached photo appears, the problem of the wall/joint failure at the corner is easily visible. I'm requesting information on the correct method for making a permanent repair. Thanks.
Name:	2012 05 06_0100 fb.jpg
- Larry
Old 05-19-2012, 03:38 PM   #5
lwp99's Avatar
Any ideas? Thanks
- Larry
Old 09-14-2012, 02:32 PM   #6
USN/LAPD Retired
Safari-Rick's Avatar
North Las Vegas , United States
I have the same problem. I moved from SoCal to North Las Vegas where the air is real dry. I have to admit that I had the problem the first year in CA. I bought it new. Took it in under warrenty for repairs and all they did was "tack" it back together. Another airstreamer (bobsunlee) had the same problem too with his 2005.
I talked to him and he screwed his in . I`m using "Liquid Nails for Paneling" and screws. Hoping this will work. IF not, then I`ll attempt straping the corners.
2007 Dodge Ram Quadcab 6.7L Diesel w/jakebrake
"Better to have more then you need, then need more then you have because you don't have enough!"
AIR #: 8129
Safari-Rick is offline   Reply With Quote
Old 09-14-2012, 02:43 PM   #7
lwp99's Avatar
Thanks for your response.
I finally used a construction adhesive and 23g brads in May. I'd tried 18g brads the first effort - they didn't hold. Between the adhesive and brads, the joint appears to be holding - this after a 6,000 mile trip this summer.
Good luck with your repairs.
- Larry
