The part of the strip that goes between the two panels has "barbs" to lock behind the panels. Check to see if yours ar there or broken off. Also it looks like maybe it needs to be slid up at the top or down at the bottom to take the curve out.
If all else fails, that is a part available from your dealer, at least when I needed some in white it was.
Al
