Old 06-23-2009, 09:05 PM   #1
2007 25' International CCD FB
San Antonio , Texas
Interior heat build up
I have a relatively new 07 25 FB and am concerned about how to store it when not in use. I will eventually build a shelter for it, but in the meantime it is in the driveway of one of my houses, and once a week I will turn the fantastic fan on and crack some windows to ventilate it, but in my absence the Texas sun can get quite hot and the interior tempertures get pretty high. So do I keep the shades drawn and expose them to the sun, or do I let the interior be subjected to the sun? At a minimum, I have the vents open in the head and shower. My thoughts are that to keep the Fantastic fan on would create it's own set of problems, in addition to the fact that I would have to remain plugged into shore power.
Any suggestions?
Barry
Barry Parkof is offline   Reply With Quote
Old 06-23-2009, 09:26 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
What we have done is install a Maxx-air vent cover over one of the vents, and simply open the vent as far as the cover will allow. The cover will keep the rain out, unless you have a tornado (in which case it won't matter), and the vent will let the heat escape. Keep the drapes closed, and you can put some of the insulating foil like you find in sun shields for car windshields in the windows.
Old 06-23-2009, 10:18 PM   #3
Silverwanabe's Avatar
1967 26' Overlander
Winston Salem , North Carolina
Images: 107
Hi,
It is very wise to protect the interior from the sun.
Overlander63's ideas are excellent.
A covered shelter is the best option, but that is not available for every owner.
Wish I had a shelter, NC summer sun is harsh too.
Greg
Winston Salem, NC
WBCCI 5218,
Corresponding Secretary Piedmont NC Unit 161,
1967 Overlander International.
1979 Avion 30ft rear bath
TV's 88 Chevy Suburban 454, 3:42, TH400
95 Cadillac FW Brougham, LT1,3:42, 7k tow pk.
Silverwanabe is offline   Reply With Quote
Old 06-24-2009, 02:12 PM   #4
San Antonio , Texas
That's an excellent idea. Thanks. What's involved with the installation of the Maxx Air Vent Cover? Can I do it from the inside or do I need to get on the roof? I am concerned with denting the roof if I am working on it. I know to stay on the ribs, but not having been on it before, makes me wonder how fragile the skin is.
Old 06-24-2009, 02:25 PM   #5
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
One version of the Fantastic Fan automatically closes when it rains. Perhaps there's a kit to convert yours.
We open the door and runs one or two of the fans every couple of days. We have a solar panel, so that keeps the battery charged and the fans draw very little power. Even after more than 1 1/2 years, we still get the chemical smell from the materials they use in building these, so we want to keep airing it out besides reduce the heat.
Gene
Old 06-24-2009, 10:19 PM   #6
San Antonio , Texas
Thanks Gene
My Fantastic Fan does have the rain sensor, but I did not think that it would be good for the fan motor to keep it running 24 / 7. I also believe that I have the solar pre-wire, and maybe I should install some panels. Do you know what is involved with that?
thanks
Using the heat pump/heat strip instead of furnace. crazylev On The Road... 38 10-28-2016 07:58 PM
Build it Yourself? craftsman General Repair Forum 16 08-10-2007 09:47 AM
Build-a-Rally Edie The Rally Zone 33 04-29-2004 10:14 PM
1973 Sovereign Redwood Interior Custom Build Pacer1 1970 - 1973 Sovereign 1 04-18-2004 04:06 PM
