Old 04-20-2015, 08:28 AM   #1
gadgetat's Avatar
2004 25' Safari
Prescott , Arizona
Send a message via AIM to gadgetat Send a message via Yahoo to gadgetat
Interior Door Handle Came off last night
Hi all! Hoping for some advice and wisdom.
Last night while parked in Gila Bend Jodi woke up to my battery backup alarm going off. Park power was off, and she went to check the park's power box. Well, upon trying to open the door to get out the door handle came off in her hand!!!
So @ 1:30 a.m. I was up, and we went out the emergency exit. The latch mechanism still works from the outside, but the inside door handle is completely off.
Do I need to replace the whole door latch? Can I repair and reconnect the handle. Any thoughts would be appreciated.
Oh, and this is a 2004 Airstream Safari 25 footer.
Rich C.
WBCCI #2551 | blog
gadgetat is offline   Reply With Quote
Old 04-20-2015, 05:32 PM   #2
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
I don't have an answer - but that is scary! So sorry you had that experience!
Does the inside of the latch look like it could be moved by a screwdriver?
Either way, good luck getting that repaired.
SteveSueMac is online now   Reply With Quote
Old 04-20-2015, 06:34 PM   #3
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
The handle should be replaceable.
Peace and Blessings..
Channing
WBCCI# 30676
Old 04-23-2016, 06:53 PM   #4
MarkJUrban's Avatar
2016 30' International
Richfield , Ohio
Hey guys, I just had the same thing happen. 2016 international. What was the solution? Is this something I can easily repair or will I need to request a new one?
MarkJUrban is offline   Reply With Quote
Old 04-23-2016, 07:11 PM   #5
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
2016 - under warranty - go to the factory, make them fix it.
2004 - boy I don't know but it looks like it sheared off from the picture - I'm guessing but this looks like something that will have to be replaced - meanwhile - take it apart and look at the pieces. I doubt that Airstream actually manufactures this piece. They ASSEMBLE Airstreams using a lot of standard industry parts. It's likely that the same lock is used on dozens of SOB's so it's likely you can find a replacement at any dealer or any RV junkyard.
Let us know how it works out please - I have a 2012 - so sooner or later - snap and OH (edited out for good taste).
Paula
Old 05-15-2016, 04:51 PM   #6
MarkJUrban's Avatar
Richfield , Ohio
Airstream mailed me a replacement handle. It was not something I could have fixed. The handle is a pressed fit into the bracket.
The fist pic is the handle that fell off
Old 05-15-2016, 04:53 PM   #7
MarkJUrban's Avatar
Richfield , Ohio
Replacement handle pressed fit.
Old 08-26-2016, 07:00 PM   #8
Watertown , Massachusetts
Shut the door!
This happened to us last week. It's actually pretty easy to fix. The door mechanism is made by TriMark, but you don't need a anything but a screwdriver and hammer to fix it. The trick is getting it back together properly. MarkJUrban is correct, it is just a press fit. (Cheap way to make it, IMHO.)
All you do is remove the 4 screws of the black panel that the door handle fits into - it's on the inside of the trailer. When you do that it's likely that the "D" shaped piece falls off, since the press fit failed. So, put it back together, and make sure the door lock slide is in the unlocked position. The handle should be positioned relative to the panel so that it would be parallel to the floor if it were in place, and that "D" piece is placed with the two little legs pointing down towards the floor.
Take a hammer and pound on the edges of the square so that you flare the metal a little bit, creating a new press fit. Now all you have to do is put the panel and the handle back on with those 4 screws.
The tricky part is getting the feet of those little legs in the right place in the mechanism so that the handle works again. This is difficult to describe and impossible to actually photograph, but the notch that is cut to make the little legs is there for a purpose, and you have to get each leg on one side of part of the mechanism. The location of the holes for the 4 screws will more or less tell you where it goes.
We no longer use this handle to close the door from the inside. The handle on the screen door works just fine to close both doors.
But, as I said, this isn't a terrific design. There is a little hole in the middle of that square part of the handle, and that should have a screw that holds a little washer to hold the whole thing together. But, I don't know if there is room in the mechanism for all that. My plan it to take it apart again and reinstall it with a little bit of putty or clay with a piece of plastic wrap on it (so it doesn't stick except to one side). I'll put the panel back together to squeeze down the putty, and then take it apart again. The thickness of the putty will let me know how much space there is and whether I can put threads inside that little hole and fit it with a metal screw and washer. If there is no space, then this won't work of course. . . . . and I'll have to think of something else or just live with the risk of it failing again.
BTW, your indication that the handle is about to fail is that the door handle seems a little sloppy.
sallye is offline   Reply With Quote
Interior Door Handle Came Off in Wife's Hand... gquake Doors & Locks 4 05-05-2014 12:26 PM
Interior handle of front door fell off.... holtenc Doors & Locks 4 11-06-2013 02:26 PM
Shub Door Came Off!!!! Devoman General Interior Topics 3 10-23-2009 10:43 PM
Hitch ball came off while driving holmestk On The Road... 17 10-05-2009 06:33 AM
Snap stud head came off! TennisMan Awnings 8 07-11-2009 10:39 AM
