Old 01-24-2014, 03:54 PM   #1
2007 20' Safari SE
charleston , South Carolina
Interior Dome Light Lens Replacement
I have a 2007 Safari SE20 that got rather warm inside when we had a lot of the lights turned on. I corrected that problem with the replacement all of the bulbs with LED's. The problem I now have is with the Dome lights. The white opaque lenses greatly reduce the brightness of the LED's in those fixtures. I have been searching for clear replacement lenses on line but can't find them. Any suggestions as to a web site.
Thanks.
harleyag70 is offline   Reply With Quote
Old 01-25-2014, 03:02 AM   #2
2005 19' Safari
GLENDALE , AZ
The LED bulbs that we installed are slightly brighter than the incandescent automotive bulbs they replaced. You might want to test a couple of these to see if they are brighter in your Airstream:
http://www.airforums.com/forums/f447...ml#post1350932
Regarding the replacement lenses, you might want to check your local Airstream dealer, Camping World or other RV parts store. Here are a couple of links that I found:
Search - dome light lense - Camping World
http://www.alsrv.com/content/p/8/sty...ome+light+lens
Stereo With Overhead light?? Eliminator46 Audio, Video & TV 10 05-20-2011 02:12 PM
first ceiling light Segue Lights - Interior & Exterior 2 05-14-2011 01:18 PM
Propane light doesn't go off dekew Refrigerators 7 05-07-2011 02:10 PM
Replacement Gold Cone Light for '58 mello mike Lights - Interior & Exterior 7 03-17-2011 10:56 PM
