Old 09-02-2015, 08:40 AM   #1
West Bloomfield , Michigan
Smile Interior Aluminum Rivets
Air Forum:
Looking for advice re: advisability of moving from aluminum to steel rivets. After each trip it seems like 2-4 interior aluminum rivets have sheared and require replacement. Please advise re: pros and cons of replacing interior sheared aluminum rivets with steal rivets.
Ric Peterson
Riccamper is offline   Reply With Quote
Old 09-02-2015, 08:56 AM   #2
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
Welcome to the forums!
What year/size/model of trailer do you have?
Well, it seems that the general advice is always to go with aluminum mandrel rivets so that they will not rust/corrode. That being said, all/most of the interior rivets on my '73 were steel mandrels, and rust/corrosion didn't seem to be a big issue.
Regardless of the type of rivets, popping and shearing rivets is not normal. I would suggest that sheared rivets are just a symptom of a bigger problem. You might have a bad axle, out of ballance running gear, damaged frame, etc...
good luck!
Old 09-02-2015, 08:57 AM   #3
Free Range Human
Drathaar's Avatar
2012 25' FB Flying Cloud
Twin Rocks , Oregon
I'd be looking for the reason you're shearing rivets before looking for alternative fasteners. It sounds like you're getting an extremely rough ride whether from the trailer, road or your tow vehicle setup.
There's also the possibility of galvanic action between dissimilar metals. Probably remote, but possible.
Old 09-02-2015, 09:02 AM   #4
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
I second Dratharr.
Shearing rivets indicates a real problem with axles and/or wheel balance.
Not the the rivets.
Steel rivets will lead to crack sheets.
Regards,
JD
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 09-02-2015, 09:05 AM   #5
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
I agree with JD.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 09-02-2015, 09:48 AM   #6
Mission , Texas
Yep ...
Why are the rivets shearing?
Axles need replacing?
Wheels not balanced?
nrgtrakr is offline   Reply With Quote
Old 09-02-2015, 09:49 AM   #7
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Ditto, fix the cause first before applying band aids. But to answer your actual question. Use all aluminum rivets.
MICHAEL
Old 09-02-2015, 11:16 AM   #8
Originally Posted by RicPeterson View Post
Air Forum:
Ric Peterson
Shearing rivets is caused by the shell flexing.
That flexing is caused by many thing unbalanced running gear, worn out torsion axles, excessive rated tow vehicles, and of co roads.
Fix the cause before you attempt tp modify.
Steel rivets are a no-no in aluminum. All they will do is make the holes in the aluminum larger, until you fix the flexing issue.
RIVETS, Rivets, and rivets Over59 Ribs, Skins & Rivets 31 10-06-2015 01:53 PM
Buck rivets or Olympic rivets? Sparkygus Ribs, Skins & Rivets 20 02-28-2009 09:33 AM
Lousy Rivets!/Weak rivets sunk the Titantic? 1956Safari Off Topic Forum 14 04-18-2008 02:35 PM
Olympic Shaved Rivets vs. Buck Rivets with Dimple msjaarda Ribs, Skins & Rivets 8 03-16-2007 11:00 PM
