Old 03-30-2009, 01:52 PM   #1
Holland's Avatar
1971 27' Overlander
1963 22' Safari
Venlo
Instructions on how to replace rubbers on termination valve thetford
Hi,
I have just received my thetford Slide EZ valve replacement set it contains some o-rings and a gasket seal. Great ! but I have no clue on how to start replacing them, who can give me simple instructions? For example, do I start off by loosening the belly pan, or can I start elsewhere? I own a 1971 Overlander, and the termination valve is situated on the back side, where the bumper sits.After emptying our tank last time,we could not completely shut the "guillotine", as there was something blocking the passage, it seemed to be a rubber ring, so I think it needs a new one.I am sorry for my poor english, but I am dutch, so please be mild with technical words on me...
Thanks for your tips, we want to start this weekend, as weather conditions will be mild, first time this year, and the Airstream is now outside, that's why.
Cheers,
Pieter and Kai
Holland is offline   Reply With Quote
Old 03-30-2009, 02:47 PM   #2
Originally Posted by Holland View Post
Hi,
Cheers,
Pieter and Kai
When your all done, you will have but one question.
Why didn't I replace the valve and save all the headaches?
We do not recommend gasket changes on valves that are old.
Way too many problems.
Mid-bath termination valve fix Zeppelinium Waste Systems, Tanks & Totes 14 01-25-2013 12:49 PM
Replace a Thetford Valve with a Valterra? thunder433 Waste Systems, Tanks & Totes 2 03-03-2008 04:41 PM
Only one Thetford Valve? The Flintstones Waste Systems, Tanks & Totes 10 10-09-2006 08:53 PM
Thetford Valve garyphelps Sinks, Showers & Toilets 1 08-27-2006 07:54 PM
Rebuild or replace old Thetford dump valve? 63air Waste Systems, Tanks & Totes 7 05-21-2006 02:47 AM
