Old 02-29-2016, 05:52 PM   #1
carl2591's Avatar
2005 31' Classic
Garner, , North Carolina
installing skylight in shower, how hard etc
getting a 2005 31D classic and don't think there is a skylight in shower stall. (i remember it being kinda dark on sunny day) so was wondering about installing a small skylight or something to bring in natural light in a dark shower.
I have the tubular skylight in my house and like the concept but not sure about the RV world.
any ideas or sites to visit to see more.
Carl, Raleigh NC
2-24-16 got a 2005 Classic 31D
TUG2.net check it out for good rental deals
2003 F-250 SD, CC, 7.3L PowerStroke
WBCCI#1691, Piedmont Airstream Club, Unit #161, Region #3
carl2591 is offline   Reply With Quote
Old 03-01-2016, 01:17 PM   #2
carl2591's Avatar
2005 31' Classic
guess its too hard to do judging from the responses to the post.
Carl, Raleigh NC
Old 03-01-2016, 02:37 PM   #3
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
Nah, it's easy to cut a hole in the roof!
I love sky lights, especially in the shower!
Cut and caulk away!
Old 03-02-2016, 07:00 AM   #4
carl2591's Avatar
2005 31' Classic
thanks that sorta what i was thinking. are there any smaller type skylights to use.. most of the ones i see are 24 x24 or larger. don't need something that size maybe like a 10 x10 or so.. I have not been able to find one that small..
any advise??
Cut and caulk away!
Carl, Raleigh NC
Old 03-02-2016, 08:28 AM   #5
1974 Argosy 20
Kooskia , Idaho
Being a snarky contrarian, and considering the amount of time you spend in the shower each day vs. the extra holes in the roof, the structural problems if you run into a rib, the leak potential etc, just put a nice LED in the shower and use it for the few minutes a day you need it.
Old 03-02-2016, 02:21 PM   #6
carl2591's Avatar
2005 31' Classic
snarky contrarian that make sense.. that does sound like a better plan. now to get a brighter LED for the shower light unit and on to other plans..
Carl, Raleigh NC
Old 03-02-2016, 02:54 PM   #7
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
FANTASTIC FAN instead
How about eliminating the cheap noisy fan in the shower, enlarging the hole and installing a fantastic fan? You get a lot of light and can effectively exhaust the condensation.
I have a one piece bath in my Avion and had Frank Yensan replace my vent with a Fantastic. He actually got the one with the remote control... which after laughing for about 5 seconds suddenly seemed brilliant to me. Ever found yourself seated and suddenly wishing you'd turned the fan on first (three friends are sitting in the living room helping you cut out quilt pieces for a local hospital auction and the chili and beer you had for lunch is ........oooh). So you grab the remote and the evidence vanishes completely!
Old 03-02-2016, 05:21 PM   #8
"Space A" S/O Registry 11
2006 34' Classic S/O
Fort Worth , Texas
Contact these folks. The owner owns an A/S so He now makes them for others. I sure like mine. Never will leak. Just give them your inside hole measurements with out inside trim.
Maxim Skylights (Airstream skylights)
1630 Terre Colony Court
Dallas, TX 75414
888 222 4898
214 905 2021
Fax 1-214-905-2024
guskmg
Old 03-02-2016, 06:24 PM   #9
Hittenstiehl's Avatar
1961 28' Ambassador
1961 19' Globetrotter
Mesa , Arizona
You could also make a small functioning or non functioning window/porthole in your shower wall.
If cutting a hole in the roof is comfortable for you then cutting one between the side ribs would work also.
Hittenstiehl
Hittenstiehl is offline   Reply With Quote
Old 03-02-2016, 06:57 PM   #10
1977 31' Excella 500
Dallas , Texas
A solar tube is a better thought. I am a HAAG R/C Inspector, and a roofer so this is something with which I have some expertise. Why solar tube? It is round, It is smaller, a 10" or 14" I'd say go 10. It has a dome that can have a trim-able/ rotatable reflective surface that will better direct light down by setting the orientation... i.e., set it to East/West such that it reflects the morning and afternoon sun. The dome is stronger and smaller. Easy to rivet down with caulk. Buy it off Amazon without a tube.
Jack Moore is offline   Reply With Quote
Old 03-02-2016, 07:09 PM   #11
Dallas , Texas
If I were doing it, I would take the standard flashing, which is designed to flash with shingles or some flat sheet roofing material, and trim it down to a 2.5" base. I would use the caulk under that base and pop rivet it down. Me, I would go over that base with a self-leveling caulk. Of course it comes with an inside finish ring. These often snap in place. You can customize the install pretty easily.
Old 03-03-2016, 01:59 PM   #12
carl2591's Avatar
2005 31' Classic
Jack
I like your idea.. here is the tubular skylight we have worked with before. The base is spun alum so cutting would not be a issue.. I do wonder with the slope of the roof on a 10" model in which the base diameter is actually 15"..
http://www.nltubular.com/skylight-mo...-skylight.html
while it sound like a good idea it might be easier to put a stronger light in or add a light for the shower area.
good ideas non the less..
Carl, Raleigh NC
Old 03-03-2016, 02:11 PM   #13
carl2591's Avatar
2005 31' Classic
Paula that is so true and funny as heck.. I bout fell out the chair on that one but food for thought.. (get it) food for thought.. LOLOLOL HAHA....
Carl, Raleigh NC
Old 03-03-2016, 04:05 PM   #14
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
Isn't the roof over the shower more on the curve, this might make it a problem to mount. Put a Maxim skylight in the hallway on the roof centerline by the shower . I have one next to the shower. Between the light in the shower and the skylight the interior is very lit up.
Kelvin
Installing Outdoor Shower Killo1 Sinks, Showers & Toilets 24 03-31-2007 10:41 PM
Relocating tanks, sinks, shower, toilet etc. Billyb Sinks, Showers & Toilets 8 11-02-2004 12:21 AM
Skylight part question ColtSAA45 Roof Vents, Skylights & Fans 3 04-22-2004 08:05 PM
Double seals on skylight? TomW Roof Vents, Skylights & Fans 1 03-01-2004 08:44 AM
Skylight - WARNING - possible Problem apple 1 Roof Vents, Skylights & Fans 0 03-24-2002 09:16 AM
