08-03-2011, 10:46 AM
2006 30' Classic
1970 25' Tradewind
Georgetown
We are wanting to purchase a flagpole holder. Does anyone know who to contact? TIA
Victoria & Joseph
08-03-2011, 10:58 AM
1993 34' Excella
york
, South Carolina
2tex, I make a very nice one, Aluminum, with a super nice mounting bracket made on it. It will mount on a 2" or 21/4" jack post & will clear the light. Holds 3 flags. I use aluminum painters poles from Lowes . I am currently out of stock but hope to have some next couple days. Send me a PM if you are interested. John
If I'm not here, I'll be somewhere else.
2007 Dodge Crew Cab 6.7 Cummins 6 speed manual DRW factory installed optional exhaust brake Leer Cap
12 Tires on the ground
Are you kind?
WBCCI # 3892
AIR # 43788
John & Susan
08-03-2011, 03:38 PM
1997 34' Limited
South of Atlanta
, Georgia
I have a message out to Robandzoe, but haven't heard back yet. When I do I will pass it. I need to install a 5 pole unit.
Craig and Carol
1997 34' Excella 1000
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
02-20-2012, 09:08 PM
2009 34' Panamerica
2008 22' Safari
Detroit
, Michigan
Airstream 5-Pole Flag Pole Holder
Victoria & Joseph
Search using the above title at Ebay. Nice unit and HEAVY DUTY. Price includes shipping.
02-21-2012, 04:27 AM
Air2
1990 34' Excella
York
, South Carolina
flag holder
sandlapper makes a really nice flag holder. it is easy to mount and looks really good. check him out on the commercial listings for flag holders
Wanna roll on down the road...let it roll!!
02-21-2012, 06:13 AM
2005 28' International CCD
Arlington
, Virginia
I just received and installed mine from John, IT'S AWESOME! Wait for John to get more in stock and order it up. I picked up my Lowe's painters poles this weekend (don't forget to pick up the big hitch clips from the hardware aisle for the flags!) and they work great.
One tip on the poles: I recommend not bothering trying to get the plastic handles off. I tried for about ten minutes before rage-quitting, then broke out my hacksaw and just cut them off (using the handle as a handy cutting guide!). Only lost three inches on a twelve foot pole, they fit perfectly in the flag holder.
My new gravel pad out back is almost ready, when my AS is set up I'll put up all the flags and share some pictures.
Cheers
Arlington, Virginia
02-21-2012, 11:01 AM
#21
1993 34' Excella
york
, South Carolina
Jim, those handles are tough, the stickers even tougher. I stuck an old screw driver through the hole in the handle, then whacked the screwdriver to knock the handle off. Takes an extra hand though. The stickers must have some sort of nuclear grade glue on them. Takes some serious work with lacquer thinner and a stick. And the poles that Mr. LONGARM sells are even tougher to get the stickers off of. Along with the thinner they require about 6 beers.
Looking forward to the pics. John
Are you kind?
WBCCI # 3892
AIR # 43788
John & Susan
02-21-2012, 12:06 PM
#22
Arlington
, Virginia
John, you aren't kidding about those damned stickers. I even tried a heat gun on them to loosen the glue, no luck getting more than a shred off before it tore. Maybe Goof-Off or something will do the trick.
I had another idea - if my kids misbehave while camping or at a rally, punishment will be half an hour of sticker removal. At that rate, I'll have them all off in a day or two. ;-)
Cheers,
02-21-2012, 12:22 PM
#23
CASA3805
1984 27' Sovereign
Corpus Christi
good product
Can't go wrong with the holder from Sandlapper. Precision made, no need to be getting hose clamps or other securing devices. All parts included, even has spacers in case they are needed .
Chuck & Skye
Rock and Roll Will Never Die!
WBCCI 3805
AIR 54011 Since July 2011
02-21-2012, 03:42 PM
#24
1983 34' Excella
1967 24' Tradewind
Little Rock
, Arkansas
Cheers,
Are you kidding? Tell them to be careful because the stickers absolutely cannot be damaged and have to remain on the poles.
They should be off quickly that way.
Vaughan
02-21-2012, 06:13 PM
#25
1993 34' Excella
york
, South Carolina
Originally Posted by vswingfield
are you kidding? Tell them to be careful because the stickers absolutely cannot be damaged and have to remain on the poles.
works every time!
Are you kind?
WBCCI # 3892
AIR # 43788
John & Susan
02-27-2012, 07:32 PM
#26
Arlington
, Virginia
Sandlapper Flag Holder
All -
Here's my nice new setup, with the flag holder made by John (sandlapper). Flag poles as discussed from Lowe's, the flags are attached with hitch pin clips.
I'll have these set up at the BASH III rally in July and the WBCU Capital Kick-Off Rally in late April, if folks would like to stop by and take a look.
Cheers,
| Thread Tools |
| Display Modes |
